No spark
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5612
    No spark
    I replaced the ignition rotor, distributor cap and ignition harness about 5 months ago. All the sudden I have no spark going to the plugs. I'm pretty sure the crank sensor is okay, but my question is, could it be the whole cars computer? I took it out a few minutes ago and noticed that it has been rebuilt in 2002 by the PO. Think it may have something to do with that?
  • Cabriolet
    • 9620
    crank but no spark is bad CPS
    Much wow
    I hate 4 doors
    • Jdesign
      • Jun 2012
      • 198
      Did you check you Ignition coil?
        Before going any further, check to see if the timing belt is intact. You won't see spark at the plugs if the cam isn't turning.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5612
          I tested the ignition coil and it checks out. As for the timing belt, it has like 10 miles on it, I just replaced it. I'll have to look at the crank sensor one more time.
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5612
            Tested the coil, tested the crank sensor and they still check out to be fine. Now my suspicion is an alarm.
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5612
              I'm in a pickle now.. I'll give a more comprehensive story now. I recently rebuilt the cylinder head and the block and the car was running beautifully. I got in my car the next morning and my car wouldn't start due to no spark. After further investigation i found an after market alarm system that was killing my igntion and bypassed it. After regaining the spark the car still wont start. I've performance compression test and test the fuel pressure and they both passed. I'm stumped. Im pretty cheap buzzed but i hope this gives an idea of what im dealing with.
                If you have no spark and power isn't being supplied to the fuel pumps when cranking, the DME isn't getting timing data from the CPS or the DME isn't running. Know that a CPS can ohm out okay, but still not work. The following check list should help find the problem.
                For the engine to run the following conditions must be met:
                Power on DME pins:
                27 Start Input
                18 Un-switched Power input
                37 Power Input from Main Relay
                Ground on DME pins 2, 14, 19, 24
                Timing data from the CPS on DME pins 47 & 48 from a rotating engine
                To have spark power must be present at the coil positive and ground pulses
                from the DME's pin 1 must reach the coil negative. Power to the coil is
                controlled by the ignition switch via C101. When checking for spark, use the
                output lead from the coil to eliminate the distributor, rotor and plug wires.
                To have injector firing power must be present at each injector and ground
                pulses from the DME's pin 16 (Bank1) and pin 17 (Bank2) must reach the
                respective injector bank. Note that the injectors are wired as two banks of
                three. With cylinder 1,3,5 being bank 1 and 2,4,6 being bank 2. Power to the
                injectors is controlled by the main relay. Injector firing is best checked
                with a noid light.
                The fuel pump relay must have power on pin 86 (relay coil) from the main relay
                output (pin 87) and power on pin 30. The DME will ground pin 85 to turn on the
                relay and power the pump(s) via pin 87. Of the above, only the fuel pump power
                is fused. So if the there's power at pin 87, but not at the pump, check fuse
                11.
                The main relay and DME pin 18 receive power from the smaller of the two wires
                that connect to the battery's positive terminal. That wire incorporates an
                in-line fuse. When the DME is presented with a start signal, it grounds the
                main relay pin 85 and furnishes power to the fuel pump relay, injectors, and
                DME.
                Troubleshooting:
                Disconnect the battery and the DME cable. Then:
                1) Disconnect the coil negative and check continuity from that connector to
                DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
                2) Check the resistance across DME 47 & 48, which should be 500-560 ohms. If
                the CPS is dismounted, the resistance can be seen to change from about 500 to
                540-560 ohms when a ferrous object is brought to the face of the
                sensor. Neither pin should be grounded.
                3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
                pump relay 85.
                Reconnect the coil, remount the CPS (air gap should be 1mm), plug the
                relays back in, reconnect the DME, and connect the battery. Then do the
                following checks:
                1) With the key off, verify that power is present at DME pin 18 and main relay
                86 & 30.
                2) With the key on, verify that power is present at DME pin 27 and pin
                18. Power to pin 18 is from the main relay and there should be power to the
                injectors and fuel pump relay.
                3) With the key on, verify that no voltage is present at the DME grounds (2,
                14, 19, 24).
                4) Verify that power is present at the coil positive and at fuel pump relay
                pin 30. Those get switched power from the ignition switch via C101.
                The engine will start and run (if poorly) with only those connections to the
                DME in place. The other signals from Cylinder ID, AFM, temp sensor, etc., are
                necessary for proper operation. But they won't prevent the engine from firing.
                IMPORTANT:
                A power check means seeing a voltage within about a tenth of a volt of what
                you measure across the battery terminals, which should be at least 12.6v on a
                charged battery.
                A continuity check means seeing less that 1 ohm of resistance.
                An open circuit means seeing a resistance of at least 100k ohms.
                A good quality auto-ranging digital multimeter will make these tests much
                easier.
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5612
                  Thank you, good sir. Come around Monday I'll go through this checklist.
