3RD brake light wiring question
  • KeeperJones
    • 240
    So I pulled my cabrio 3rd brake light today and am a little confused on the wiring. There are four wires. So I am looking at my Bently and not getting too far. The green/red comes directly off the switch. One of the green/black comes from the active check control unit, which I am guessing is related to the check panel. The other green/black goes to the rear light check relay. The brown is shown ending with three lines of decreasing size under it. If I remember right it signifies a ground and I am guessing grounds the little circuit board that all the wires run through.
    So a couple of questions. I pulled the brake light and snipped the wires. I am going to use a Zender spoiler with a 3rd brake light that only has two wires. Do I need to pull the circuit board out of the oem light and use it? Or if I just use two wires (I assume it is the green/red and the green/black going to the rear light check relay) will it cause any issues with the auto check system?
    I am not putting the spoiler on until next weekend and I need to get the brakelights working again. Is crossing the green/red and the green/black the right thing to do to get them working temporarily?
    I searched around a bit and couldn't find anything on the wiring, hopefully not because it a total noob question. Anyway, thanks for any advice.
  • KeeperJones
    • 240
    Ok, so I am glad I checked first. Green/red and brown get the light working and connecting the two green/black bypass the check system for the 3rd light.
    BTW, cabrio owners, you might want to pull your trunk lid 3rd brake light and inspect it. I had some serious rust going on an otherwise rust free car.
    • Disaster Inc
      • Oct 2007
      • 429
      Hey, thanks for the info. My Cabrio has an is trunk lid, so the light has been on the check panel for a while. I'll try jumping those two wires, then only one check light to go!
      • KeeperJones
        • 240
        yes
        It worked for me. I bought a zender with a 3rd light from elguapo84 and am doing away with my oem. Because it is LED it is not monitorible. I couldn't believe the rust under there. There was no eveidence in the trunk or outside.
        • DaveSmed
          • Apr 2007
          • 1407
          Good stuff. Guys with rusty lids, you have the early or late style third brake light?
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • Disaster Inc
            • Oct 2007
            • 429
            Originally posted by DaveSmed
            Good stuff.
            I agree us Cab guys gotta stick together. The way I look at my car is yeah its cool. and "Hey by the way, the top goes down"...then it becomes way cool......Chicks love it...Cabs FTMFW!
            • cactusjacks1
              • Sep 2004
              • 1216
              So, if you have completely done away with the third brake light, you jump the 2 wires (keeperjones talks of in post #2) & the "brake light" warning bulb on the "check board" will go out??
              [I
              • DaveSmed
                • Apr 2007
                • 1407
                Yup.
                -Dave
                • cactusjacks1
                  • Sep 2004
                  • 1216
                  You have found a real simple fix - I made a jumper wire to connect the 2 & WALA !! brake warning light on the check panel is OUT.
                  Any hints on the SRS light staying on when you replace the air bag steering wheel with a non air bag one??
                  Thanks a 1,000,000 !!
                  Jack
                  [I
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    Glad to hear it helped.
                    Under the drivers knee bolster, there is an orange box near the ABS computer. It has 4 (IIRC) orange connectors. Unplug them. No more light.
                    -Dave
                    • rkettner
                      • Jun 2007
                      • 367
                      the third brake light can also be the source of water getting into your trunk as i found out.
                      • Garageaholic
                        Freestyle Fabricator
                        • Dec 2005
                        • 5204
                        I am going to revive this thread...
                        I was troubleshooting my brake check light system.. I will try this soon, but I want it to work LIKE IT SHOULD....
                        With that being said, I inspected the circuit board within the 3rd brakelight housing. There was some corrosion, so i cleaned it off and the check light doesn't go out... I may give up and simply connect the wires, but I figure that I would give it a good college shot..
                        How would one test this? What is the proper resistance of the bulb that one should use?
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        Instagram.com/garageaholic
                        Youtube.com/garageaholic
                        • Kwaaahhh
                          • Apr 2008
                          • 843
                          Any chance some have some pics of the wiring done? Got a IS trunk painting right now to swap on my vert. :up:
                          • Kwaaahhh
                            • Apr 2008
                            • 843
                            So I jumped the wire OP said. But I was wondering does your guys check brake light still stay on, until you hit the brakes and it goes away?
                            • T.Dot_E30
                              • Mar 2004
                              • 286
                              yes, once you step on the brake the system knows if the brake lights work or not.
                              Hence the "Check" blinking until you do.
