Fixing front camber (e36 m3 suspension)
  • cokeisgood00
    • 152
    So I bought this e30 with the front 5 lug swap done with e36 m3 parts. He drilled holes in the towers to accomodate the struts, however I have ~5* of negative camber up front and I'd like to bring it back the other way a little bit.
    What can/should I do? Camber plates, which ones fit the drilled towers?
    86 528e b25
    00 528i
    95 525iT
    88 325is m52
    86 325es m50
    • 37829
    I hate when people do it that way. E30 strut mounts fit right on to the E36 struts.
    Since you already have the extra holes you can buy either E30 or E36 camber plates.
    Can you post a picture of your current top mount setup?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • cokeisgood00
      • 152
      Yeah, I was really confused because most things I read said to use e30 mounts.
      I'm just trying to figure out the best, cost-effective way to do this right,
      86 528e b25
      00 528i
      95 525iT
      88 325is m52
      86 325es m50
      • jalopi
        • 2370
        wow your caster must be quite low. get some ground control plates, they're one of the best IMO.
        • cokeisgood00
          • 152
          e36 or e30? Will they fit with the strut mount farther forward?
          Would I be better off getting some e30 strut assemblies w/ camber/caster plates?
          86 528e b25
          00 528i
          95 525iT
          88 325is m52
          86 325es m50
          • jalopi
            • 2370
            Per MR 325, if the e30 plates will fit on the e36 struts I'd get e30 plates. Even in the standard position you'd be gaining 3-4 degrees of caster, minimum. On the other hand, if you don't mind reverting to 4lug and all the work it entails, why not?
            Just out of curiosity... you didn't specifically mention what kind of control arms the PO used during the swap. Does this car have e46 arms? That'd explain the extra camber too.
            • cokeisgood00
              • 152
              Well I don't have any 4 lug stuff...
              It has e46 arms.
              86 528e b25
              00 528i
              95 525iT
              88 325is m52
              86 325es m50
              • jalopi
                • 2370
                Unless you have specific plans to drift the shit out of your car, get a set of e30/36 control arms. This will reel your camber back in a few degrees. For reference, my car has e46 arms and with the camber plates at full positive I'm at around -3* of camber.
                • cokeisgood00
                  • 152
                  Will I need to change out any tie rods? I've got an e36 rack, e46 arms.
                  Will it fix the caster too? Will this be the AIO solution?
                  86 528e b25
                  00 528i
                  95 525iT
                  88 325is m52
                  86 325es m50
                    • 37829
                    The caster is messed up because those strut mounts are totally wrong!
                    The camber is missed up because of those E46 control arms!
                    If you swap to 96+ E36 M3 arms, E30 M3 offset control arm bushings, and stock E30 strut mounts things will improve A LOT. You really don't even need to buy camber plates. You will want to switch to E30 or E36 tierods. It sounds like whoever did this 5 lug didn't know what they were doing.
                    What spindles does the car have? Those should be 96+ E36 M3 as well.
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • cokeisgood00
                      • 152
                      Alright, so I plan on buying all the parts MR 325 mentioned, but there's no way I can buy them all at once, and I'm running low on tire with the camber. What should I buy first. Offset bushings and mounts, then arms?
                      86 528e b25
                      00 528i
                      95 525iT
                      88 325is m52
                      86 325es m50
                      • jalopi
                        • 2370
                        Those mounts look pretty centered as far as camber goes - the thing that's gonna fix your camber most is the control arms. If you have to do em one at a time, do arms>lolis>mounts. Keep in mind though... changing any of these is gonna fuck your alignment up real good. Minus well keep rocking the current setup, save for all parts + 2 front tires and an alignment.
                        • cokeisgood00
                          • 152
                          What's the difference between e36 M arms and e36 non M arms? They look the same.
                          86 528e b25
                          00 528i
                          95 525iT
                          88 325is m52
                          86 325es m50
                          • cokeisgood00
                            • 152
                            If it makes any difference, I have e36 inner tie rods and e34 outer
                            86 528e b25
                            00 528i
                            95 525iT
                            88 325is m52
                            86 325es m50
                            • jalopi
                              • 2370
                              I think the arm angle is ever so slightly different or it's the length... one of those.
                              FWIW I'd get some kind of offset bushing and camber plates. My car felt much more stable after I put the e46 arms on my car. With the plates maxed out full positive you can reel the camber back in to about -2~2.5*.
                              people use that tie rod combo to compensate for the additional length of the e46 arms
