Found a great injector cleaning DIY!
  • silversleeper
    • Mar 2005
    • 2032
    CLICK HERE TO VIEW IT!
    I'm gonna do this to my 19 lbers this in a few weeks!
    Fuel Injector Cleaning
    By Dusty Sharp
    My fuel injection system sat around for about 4 years before I finally got around to installing and cranking it up. Needless to say, the injectors were gummed up something fierce! Here’s what I did to get mine clean.
    Injector Parts / Tools (avalible from Mr. Injector):
    • 16 O-Rings
    • 8 Spacers
    • 8 Pintle Caps
    • 8 Filters
    • #10 Machine Screw
    Use the #10 machine screw to remove the internal filter from the injectors.
    First, put together a simple injector test circuit with some aligator clips, wire, a momentary toggle switch and a spare injector harness plug (I got the injector plug at my local Carquest for a couple bucks, or you can pocket one for free at the boneyard). Put each injector in the makeshift harness and check it with the switch. You’ll hear it click when you throw the switch unless its gummed up too bad. Even if they do click, they could probably still use a cleaning.
    Next, get some fuel injector cleaner from the parts store. I like the Chemtool brand stuff in the white can with red and blue label. You’re supposed to dilute this stuff in a tank of gas but for this purpose I used it full strength. Put the injectors in a bucket and pour in the cleaner until it covers them. Remove the o-rings first or they’ll swell up like donuts and crumble off (you can buy injector o-ring kits at the parts store pretty cheap if you accidentally soak the o-rings too–BTDT). Let the injectors soak over night.
    The next morning the fluid will be full of gunk and slime from inside your injectors. As you take each injector out of the cleaner, place it into the test wire harness, place a compressed air nozzle at the spray end (backwards) and throw the switch while you give it a blast of air. Point it away from you because more gunk and slime will spew out. If you don’t have compressed air, you can blow into the end of the injector, but use short piece of clean fuel or vacuum hose between your lips and the injector to avoid getting any of that nasty cleaner in your mouth. Repeat this procedure with each injector, rinse once more in clean cleaner, then dry them off and reinstall the o-rings.
    First, put together a simple injector test circuit with some alligator clips, wire, a momentary toggle switch, and a spare injector harness plug (you can buy one new for a couple dollars or from a junkyard harness). Put each injector in the makeshift harness and check it with the switch. You’ll here it click when you throw the switch unless its gummed up too bad. Even if they do click, they could probably still use a cleaning. Next, get a bottle of professional injector cleaner from the parts store meant for the cleaning machines. Remove all the O-rings from the injectors are place them in a bucket. Pour the cleaner in until they are all covered and let them soak over night. The next morning the fluid will be full of gunk and slime from inside your injectors. As you take each injector out of the cleaner, place it into the test wire harness, place a compressed air nozzle at the spray end (backwards) and throw the switch while you give it a blast of air. Point it away from you because more gunk and slime will spew out. Do this with each one, rinse once more in clean cleaner, then dry off and reinstall the o-rings.
    After I did this my motor ran great and has ever since. Hope this helps.
    Claus Luthe is my hero.
  • silversleeper
    • Mar 2005
    • 2032
    I guess no one here is really interested in cleaning their injectors?
    • SchnellerVert
      • Sep 2005
      • 3948
      Very nice find to bad I just sent a set off to www.witchhunters.com guess I will be doing my next set by myself thou.
      I just got a set of Volvo 740 turbo injectors.
      • ethirdy
        • Nov 2007
        • 406
        Subscribed - gonna pop out my 19#'s and do this :)
        Originally posted by alpinaclone
        Since the real economy is in the shitter, I say we start our own.
        This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
        • george graves
          • 20003
          nice
          Originally posted by Matt-B
          • tjts1
            • May 2007
            • 1851
            I've been using this technique for a long time. It works fine.
            • StereoInstaller1
              GAS
              • 22679
              Wow...a DIY on injector cleaning.
              Never saw that before, thanks for posting!
              Closing SOON!
              Thanks for 10 years of fun!
              • pookieboo
                • Dec 2008
                • 11
                Nice, thanks for sharing such awesome technique.
                This my spam training account. Do not send e-mails to this address.
                spam.7xmo_fszol@hlmtechnologies.com
                Thanks. :p
                • EA8
                  • 328
                  adding this to my list of things to do ... word
                  • Jean
                    • 18228
                    Thanks! I just sent my injectors to get rebuilt and flow tested heh
                    • george graves
                      • 20003
                      Yea, can someone confirm that "flow testing" is nothing more than a chem class graduated cylinder,a stead 12v power supply, and a stop watch?
                      • M3 Ryan
                        Site Sponsor
                        • 2298
                        True. I have seen several testing machines and this is all they do to test them. They fire all 6 at a time into multiple cylinders so it doesn't matter the length of time they are on, they should all fill at the same rate.
                        '88 M3.2 S54 Lachssilber/Black
                        '07 335i Alpine/Black Sedan
                        '12 X5 3.5i Alpine/Black
                        iS Splitters For Sale, PM ME!
                        • BimmerScreamer
                          • Dec 2008
                          • 413
                          yeah the machine I used to flow test was just that.
                          Anything can be done
                          • blueapplesoda
                            • Dec 2005
                            • 1904
                            that sounds easy. i think i'm gonna have to make one of these "machines".
                            now let's say i put this together. how would i be able to control the injectors? (ie, 50% duty)
                            is it just varying the voltage?
                            • gjuu
                              • Jan 2005
                              • 78
                              If you wanted to get high tech you could hook it up to an old megasquirt and laptop or maybe a jimstim
