I've got some stuff that's been lying around for a while, and I need to unload. Items are not listed in any particular order, so be sure to look at everything! Most of this stuff could use some cleaning, and my photos aren't the best. I have too many projects going at once! All prices include shipping to the lower 48, and are OBO.
Schwartz mirrors, in really good condition with minimal chipping. Paint is still glossy, pics don't do them justice. These would be a great upgrade to any car with the base model "flat black" mirrors.
SOLD
Plug/pigtails for use with 6-pin tps. This is the plug you need if you plan to use a piggyback ecu. They are very hard to find, as it requires ruining a whole engine wiring harness to get this piece.
$25
413 red label OBDI ECU. Self-explanitory, pulled from a running car.
SOLD
OBDI Vanos engine wiring harness, pulled from an automatic E36. There is one small ground wire that has the connector snipped off, but that is the only cut, and is very easily fixed.
SOLD
735il Brake booster and remote mount brake reservoir. This is the combo you need to clear the intake manifold on your 24V swap, without increasing braking effort with an undersized booster.
SOLD
OBDI non-ews throttle body with TPS sensor attached
$30 1 left
E30 318is wire harness covers. All 3 pieces. One tab is broken on the cover, but it still snaps closed nice and tight.
$60
OBDI 24V intake manifold, to fit M50, S50, and OBDI swapped M52 and S52. One has the attached fuel lines and plastic trim piece, one is bare. The pictures are of the "more complete" one. *edit: bare one still available
$50 for the bare one.
Factory trunk light. Works as far as i know. Comes with wires attached so you can use it for the "dual light" trunk mod.
$10
m20b25 upper gasket/seal set, only missing the valve cover gasket. Includes every gasket and seal from the head gasket up. I purchased this from bavauto for $99.
$50
HUSCO armrest. missing the little braket that installs inside the center console, but that piece can be fabbed up easily. The padded part is in excellent shape with almost no wear. If it doesn't sell at this price, I will keep it.
$250
Bosch euro H1 highbeam. minimal pitting on the lens, will need new adjusters
SOLD
Intake boot, brand new. I bought the wrong part.
SOLD
m20b25 throttle body, nice and clean with a new coolant passage gasket installed.
M30B35 ignition coil, can be used on the m20 for a little extra spark.
$25
Euro wiper stalk with intensive wash. This is the stalk you need to setup the headlight wipers.
SOLD
sandblasted m20b25 valve cover, ready for paint
$40
Eaton M62 supercharger, has about 10k miles on it. was removed from a mercedes. I bought it to put on my E30, but realized i don't have the time to make it happen. It comes with the electromagnetic clutch assembly, and there is no play on the pully. you can turn the rotors with one finger.
SOLD
M20 "I" intake manifold and fuel rail
$40
SOLD
$25
SOLD
SOLD
SOLD
$30 1 left
$60
$10
$50
$250
SOLD
SOLD
$25
SOLD
$40
SOLD
$40
