FS: M52B28, ZF, 24v swap parts, wiring harness, M20 headgasket set, much more
  • broke30
    • May 2007
    • 1019
    Cast iron block M52B28- Roughly 105k miles (currently have cylinder head/valvetrain removed):$520
    ZF trans, great shape: SOLD
    E34 oil pan and pickup: SOLD
    OBDI Harness, complete. In great shape: $100 SOLD
    OBDII Harness, complete. In great shape: $125 (pending sale)
    E36 AC compressor: $50 (pending sale)
    OBDII ecu: $110
    C101 connector (E30 side) needed for 24v harness: $10
    OBDII Headers: $35 SOLD
    OBDII knock sensors: $30
    Crank position sensor harness: $10
    ICV and vacuum line, great shape: $20 SOLD
    E36 cyclone separator (CCV) with hose and mounting bracket: $10
    E30 lock cylinder (new): $12
    E30 clutch stop: $5
    E30 door plunger: $1
    E30 trunk plunger: $1
    M20 valve seals (new): $5
    E36 alternator: $30
    E36 motor mount arms (one was cracked and rewelded, can see the crack on the backside): $12
    M20 valve cover: $10
    E36 white base window switches (3): $5 each $10 for all 3
    E30 unlit window switches (3): $1 each
    E30 lit window switches (2): $1 each SOLD
    Hazard switch: $1
    M20 oil cap (new): $5
    M50 manifold and throttle body: $70
    E36 AC compressor bracket and tensioner: $20
    E36 starter: $20
    E30 IX brake booster and master cylinder: $120
    BRAND NEW PARTS:
    Thermostat gasket: $2 SOLD
    Oil filter housing gasket: $3 SOLD
    E30 Clutch master cylinder: $35
    E36 Accessory belt: $10 SOLD
    E30 OEM air filter: $8
    M50/M52/S50/S52 Rear main seal and housing gasket: $12 SOLD
    M50/M52/S50/S52 pilot bearing: $10 SOLD
    E46 automatic transmission filter and pan gasket: $28
    E34 oil pickup gasket: $1 SOLD
    M50/M52/S50/S52 front crankshaft seal: $5
    M50/M52 oil cap: $8
    M50/M52/S50/S52 clutch bolts: $10 SOLD
    E30 transmission mounts: $10 SOLD
    M52 headgasket set: $165
    M50/M52/S50/S52 head bolt set: $12
    M50/M52/S50/S52 oil pan gasket: SOLD
    Almost complete shift bushing kit (missing rubber trans tunnel boot and rear shifter mount): $50
    Temp sensor: $8
    Temp sending unit (for 24v swap): $8
    Aux fan switch: $8
    E30 AC belt: $5
    All prices are WITHOUT shipping and are OBO.
    Please let me know if you have any questions
    Thanks
    Max
  • broke30
    • May 2007
    • 1019
    I will also sell all of the 24v parts (everything in this ad minus the m20 headgasket set and e30 clutch master cylinder) for $1900.
    Max
    • mitchlevy7
      • Aug 2011
      • 672
      parts tested? especically the icv im interested in
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • broke30
        • May 2007
        • 1019
        Unfortunately no. I bought the motor and whatnot out of a good running car though, that's the best I can say about them.
        Max
        • golde30
          • 11464
          Why was the engine torn down? Overheat?
          IG: @Baye30
          • broke30
            • May 2007
            • 1019
            No, whenever I do a 24v swap I always do a mild head rebuild. No reason, that's just how I am.
            Max
            • evandael
              • Oct 2009
              • 2881
              i might be interested in the following:
              engine harness (provided it's completely uncut)
              oil pan gasket, RMS, head bolts, belts, pilot bearing
              a/c compressor
              i'm definitely interested in the a/c compressor though, and any lines that may have come with it.
              • toointoxicated60
                • Sep 2009
                • 355
                pm me price for
                M20 Head gasket set: $65
                M20 Head bolt set: $10
                shipped to 11435 thanks
                • broke30
                  • May 2007
                  • 1019
                  Pm'd
                  Max
                  • broke30
                    • May 2007
                    • 1019
                    OBDII Wiring harness and AC compressor pending sale
                    Max
                    • broke30
                      • May 2007
                      • 1019
                      Bump!
                      Max
                      • broke30
                        • May 2007
                        • 1019
                        Bump
                        Max
                        • golde30
                          • 11464
                          Willing to put that short block back together and ship?
                          IG: @Baye30
                          • broke30
                            • May 2007
                            • 1019
                            Pm'd
                            Max
                            • broke30
                              • May 2007
                              • 1019
                              HUGE UPDATE!
                              Max
