Hello R3v,
Recently finished a turbo project on my car and its left me with some leftovers from when I was NA. Figured I'd make a for sale thread, I'll keep it updated as I get new things to sell.
If its listed below its available! everything is used but in good + working order unless marked otherwise! Prices are OBO before shipping.
M50 stock green top injectors... I have 12 of these - $50 for a set of 6 or $10 individually
when I pulled them from my storage closet, I noticed one is missing the plastic green tip at the end.. (works fine but may disrupt spray pattern) This ones free if you buy some others.
M50 Stock dual mass flywheel - $100
pulled it from my car about a month ago, worked good for years. You can have my old clutch and pressure plate if you want for free with it, but I'd recommend a resurface and new clutch at the minimum.
Driveshaft - $150
Heres where things get tricky.... I bought my car with a G250 swapped into it... there's no part number anywhere on this shaft... By the looks of it online, it looks more like an e30 shaft than an e36 shaft (male splines on front half...) But I'm not 100% sure on it.... What I am 100% sure of, it will fit behind a 24v set up with a G250 trans. Otherwise it drives smooth! good u-joints.
M50tu 413 DME - I have two of these, one I know 100% works, I ran it in my e30 for the past two years. The other came with the car and I've never verified it but I have no reason to suspect it wouldn't... $80 for my verified working one. $40 if you want the unverified one!
e30 Behr fan clutch and fan - works good! - $40 (i trimmed the corners of the blades to ensure they wouldn't catch on my radiator as my m50 ran very close! you can see the trimmed area's in the second pic, had no ill effects on cooling)
AC compressor bracket + clutch pivot fork.... $10 each?
used ZF trans mounts... $5 maybe.
[/url]
Fuel sending unit for e30 - $15 (this is for the 55L single pump tank)
pic coming soon
-Maxximus
Driveshaft - $150
[/url]Fuel sending unit for e30 - $15 (this is for the 55L single pump tank)
pic coming soon
-Maxximus
