FS: Lots of M10 Parts
  • SoopaGhetto
    • 573
    Sellilng off a lot of things that i have been collecting. Its been sitting in my storage/garage and i know someone could use these!
    First off i have:
    (1) 3.64 non lsd good condition. no whine. didnt leak on me. very dirty though. (i was gonna keep it and weld it but blah)
    (1) cap
    (1) rotor
    (1) set of wires 8mm
    (1) distributor [cap and rotor were bought together and are almost brand new (used < month) wires prolly a few months distributor prolly original BUT with older distributor gear]
    (1) Crank Pulley
    (1) fan clutch (nvr over heated bc of fan)
    (2) distributor housings with pressure switch attached
    (1) JETRONIC ECU along with some wire harness and idle control unit
    (1) single chain cam sprocket
    (1) cold start injector/idle air intake
    (4) stock 14lb injectors
    (2) rocker shafts
    (1) end cam retainer
    (1) used chain 170k
    ( 8 ) rocker with BMW 85 8.2 castings on all of them
    (3) cam oilers with 1 missing a holder
    (2) timing chain piston
    (2) front cam sprocket cover
    (3) TPS (2 m10 1 m20)
    ( 8 ) valve springs
    (3) cast retainers
    (1) Stock air box non swiss cheezed
    (2) m10 AFM (1 untouched 1 touched)
    (1) merkur AFM?
    (1) set of suzuki gsxr 750 injectors/fuel rail
    (1) set of mechanical injector with lines
    Summary:
    (1) 3.64 non lsd good condition. no whine. didnt leak on me. very dirty though. (i was gonna keep it and weld it but blah) - 50 + shipping
    (1) Crank Pulley - 20 + shipping
    (1) cap
    (1) rotor
    (1) distributor [cap and rotor were bought together and are almost brand new (used < month) wires prolly a few months distributor prolly original BUT with older distributor gear**]
    cap + rotor + set of wires -> 30 + shipping
    cap + rotor + set of wires + distributor -> 40 + shipping
    (1) single chain cam sprocket - 30 + shipping
    (1) fan clutch (nvr over heated bc of fan) - 20 + shipping
    (2) distributor housings with pressure switch attached - 20 each + shipping
    (1) JETRONIC ECU along with some wire harness and idle control unit - 60 + shipping
    (1) cold start injector/idle air intake - 20 + shipping
    (4) stock 14lb injectors - 30 + shipping
    (2) rocker shafts - 20 + shipping (for both)
    (1) end cam retainer - 10 + shipping
    (1) used chain 170k - make offer + shipping
    ( 8 ) rocker with BMW 85 8.2 castings on all of them - 100 shipped
    (3) cam oilers with 1 missing a holder - 15 each + shipping
    (2) timing chain piston - 10 each + shipping
    (2) front cam sprocket cover - 15 each + shipping
    (3) TPS (2 m10 1 m20) - 20 each + shipping
    ( 8 ) stock valve springs - make offer + shipping
    (3) cast retainers
    (1) Stock air box non swiss cheezed - 35 + shipping
    (2) m10 AFM (1 untouched 1 touched) - 40 each + shipping
    (1) merkur AFM?
    (1) set of suzuki gsxr 750 injectors/fuel rail - make offer
    (1) set of mechanical injector with lines - make offer
    **i used the distributor gear out of a 2002 so that i could use a 2002 schrick cam with stock distributor
    ****Also note i ahve (2) stock cam shafts in 'ok' condition. some the lobes has some surface rust and one of the shaft has a weird looking scar but not deep - want pics/make offer
    i take paypal / any questions just ask
    i would rather trade some things bc i need a transmission for my m10
  • SoopaGhetto
    • 573
    up
    • Jean
      • 18228
      I'll take the fan clutch.
      Is the AFM and known good, no dead spots? My car has a hesitation spot between 2500-3500rpm and I think it might be AFM as everything else has been replaced.
      • SoopaGhetto
        • 573
        yea they are both good. i have one that is original to the car, then i decided to get another one bc i was going turbo and thought it would be good to have one i could mess with.
        the one i bought has had the tension spring adjusted. and the one original to my car nvr had the cap thingy removed. last time i used both 1.5 yrs ago they were fine to my knowledge
        • Jean
          • 18228
          Where do I send the $, I'll take the fan clutch for now and i'll get back to you on the AFM.
          • SoopaGhetto
            • 573
            you can send paypal to rccuffee [a t] vt [d o t] edu
            pm/aim me and we can finish the transaction
            • Jean
              • 18228
              pm sent
              • SoopaGhetto
                • 573
                replied
                • Jean
                  • 18228
                  payment sent, thanks!
                  • SoopaGhetto
                    • 573
                    up
                    • SoopaGhetto
                      • 573
                      up
