WTB: Race / Performance parts, suspension, etc
    Looking for the following for an 89 325is:
    - GC camber plates (or similar)...bought
    - Good poly rear shock mounts (IE or similar)
    - IE rear chamber/caster weld on kit
    - IE rear reinforced sway bar mounts
    - Treehouse control arm eyeballs
    - or AKG hard poly control arm offset bushings
    - AKG hard poly bushings (diff, trailing arm)
    - stainless brake lines
    - front strut bar, Sparco prefered.
    - Z3 shifter
    - Newer style thermostat housing (with extra tapped holes)
    - etc
    ...basically anything needed to get a car track ready
    I have some E30 stuff I can trade, if needed.
    <edit>
    Ok. finally bought shocks and springs.
    Ok. finally got AKG motor and tranny mounts
    Ok. finally bought GC plates
    89 325is track project / 05 x5 / 99 M3
    E30 stuff for sale | Parts I'm looking for
    I have a coilover kit, no name collars but eibach springs, can get the rates but came off a track car. The front suspension had the spring perch removed and M3 style sway bar tab welded on. Billy sport shocks/struts. IE camber plates. Brakes up front are custom wilwood with a corrado 11" rotor. I put them on my car and rolled it around, but now I'm going 5 lug so I can share wheels between e30s.
    I can get better pics, this is all I have, shows the brakes and threaded collar. http://s130.photobucket.com/albums/p...esbigwheel.jpg
    I can have them off probably next week if you're interested, and could meet somewhere half way.
      bump....
        I can make you a shifter. . . .
          How so?
            how does I can make you a shifter get a response but mine doesn't ;)
              By custom wilwood, who customized it? Is this a Massive kit?
              Which IE plates? Race or street?
              Did you shorten the tubes?
              How many miles on the struts/shocks? Part numbers?
              PM me if you have prices in mind for both.
              Thanks...
                Bump...bought shocks and struts and springs.
                  bump....anymore?
