Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
M10/M20/M30 billet adjustable fuel pressure regulators
    Group buy for stock fuel rail mount billet adjustable fuel regulator's.
    Features include:
    100% American made.
    100% all billet aluminum construction.
    100% rebuild-able.
    Viton 3-layer diaphragm rated at 100 psi constant and 300 psi burst.
    Totally adjustable from 30 psi to 100 psi.
    Separate vacuum port, no removing the line to adjust.
    Direct replacement for stock regulator.
    Group buy is for 10 regulator's. Price is $120 each shipped USPS Priority Mail. International shipping available. Payment through paypal only. Feel free to ask any questions. Thanks, Matt
    1.
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    What are the benefits of this product?
    Would you recommend it for an ITB and Turbo setup?
    Alpine White 87 325is
    Follow my build via Instagram: @SmplxCulture
      To answer your questions..
      1.What are the benefits of this product?
      Well, this gives you the ability to manually tune the fuel pressure to adjust for changes in the system. Such as larger injectors, larger fuel pumps, higher fuel demand, ect.. It's a tuning aid. Also, this one works with the stock fuel rail. Most do not, most require the use of an adapter and a remote regulator. This costs more, and adds complexity (custom mounting brackets you have to make, extra lines to and from the remote regulator). This one is also rebuild-able, most are not. A stock replacement regulator will run you 75-100 bucks, so there that too.
      2.Would you recommend it for an ITB and Turbo setup?
      Yes I would, I would recommend one for anyone doing any sort of mods to an engine. I've never known a performance car that doesn't use a adjustable fuel regulator. It's considered a standard and one of the first fuel system mods that should be done. And I can attest personally to the quality of the product. I've installed these regulators in probly 100 cars myself, ranging from simple bolt-on cars to fully built race cars. Power levels ranging from 300 to 1200+ hp cars.
      On a more specific to the ITB part. Depends on the system, some use regulators and some don't. Depends on how the car's being tuned, Alpha-N, MAP, MAF, TPS, combinations of those.
        Interested, any plans to make it accept an an fitting?
        29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
        72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
        Gewerkschaft der Polizei Sticker/Clings For Sale $8
          Count me in for one, as long as this doesn't take too long to get filled.
          Rediculously Cool!
          www.squatchboxx.com
          Instagram @squatchboxxcoolers
            Pmed I need one...
            1986 "C2 2.7 Alpina" Sedan
            1987 325ic Black Vert
              Where would you find the parts to rebuild one besides through you?
              Rediculously Cool!
              www.squatchboxx.com
                Matt that's a great price, considering an entry level one from Aeromotive is $140+ shipping and doesn't even bolt on to the stock fuel rail.
                Looks like very well made product.
                Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                ____________________________
                E-mail Panayiotisx2@gmail.com
                Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  Sorry to take so long updating this. To answer some of the question's that have been posted.
                  1. AN- fittings. There are no plan's to make it accept AN fittings as there's a unit that has that already if truly interested in that style. The upper vacuum port is a threaded design on these and I believe the fuel return port on the bottom is aswell.
                  2. Rebuild kits. These regulator's are produced by a friend's company. Kirban performance. Their mostly known within the buick gnx and mustang worlds. But produce this regulator for a porsche fitment, which is the same as ours. Rebuild kits are available direct threw Kirban.
                  The group buy must be full on this before the order is placed. Because this is a low volume piece the pricing deal is for a batch of ten total. They normally run between $160-190ea. range retail.
                  Thanks, Matt
                    Hello Matt. This looks like an awesome product! I don't know if you have a list started somewhere for this. I'm sure people have pm'd you, but I'm going to start a list here. Hope that's cool. :D
                    1. Gibbsinc
                    2.
                    3.
                    4.
                    5.
                    6.
                    7.
                    8.
                    9.
                    10.
                    91 - 325i now
                    99 - e36 M3 then
                    89 - 325i then
                    98 - e36 M3 then
                      Bump.
                      Any updates?
                      91 - 325i now
                      99 - e36 M3 then
                      89 - 325i then
                      98 - e36 M3 then
                        Does the regulator have a gauge port on it?
                        Edit: excuse my ignorance, I just looked at the pictures again haha
                          Bump
                          Let's get this group buy going!
                          91 - 325i now
                          99 - e36 M3 then
                          89 - 325i then
                          98 - e36 M3 then
                            Yeah put me on the list. I'm doing a turbo build and this looks great to me. I'd also rather purchase from a company that is manufacturing here in the good old USA.
                              1. Gibbsinc
                              2. Firemanory
                              3. Luis325
                              4. Stopsign01
                              5.
                              6.
                              7.
                              8.
                              9.
                              10.
                              91 - 325i now
                              99 - e36 M3 then
                              89 - 325i then
                              98 - e36 M3 then
