Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
JOM Coilovers
    JOM Coilovers
    Thought that a review of these was in order since so many are buying them and there are always a lot of questions about the coilovers. I purchased these in the 3rd group buy so the price was 420 shipped.
    Price & Shipping
    - Perfectly fair. It came much faster than I thought it would and it's 420 dollars for shocks and springs. Not much to complain about here.
    Packaging - Fair but not great. Items are wrapped in paper and can move around so most of the paper was torn. One shock had popped out the end but upon arrival was back inside. There was no damage or chipped paint or the like. Not a huge problem but the box is huge compared to what shipped. Could save on packaging but I imagine the box is used for every coilover system they offer so say for an E36 you would get two complete struts and rear shocks.
    Quality - Value is the word I would start with here. You can tell these shocks are not Bilstein Sports. One with any sense would imagine this would be the case based on the price but wanted to get that out here. Springs appear to be of good quality and the paint on everything was well done. The adjusters are definitely cheaper metals and the threads are sharp. Lowest quality pieces of the set are the adjusters(more below). Shocks rebound and go up as normal. No dead spots, catches or dodgey operation.
    Installation - This is trick! No modification is necessary. I am sure most reading this have installed shocks on the E30. If not the shock goes inside the strut housing. It is held in with a threaded collar. You remove the OEM collar and the replacement is threaded from JOM. The shock fits perfect into the housing and you tighten down the new collar. The trick part? The new coilover sleeve now simply screws onto this. See photos below. All fit perfect. Zero issues.
    Adjust-ability(split into two parts) - Front - Crazy the level of adjustment. From my estimation you can go from stock ride height(or maybe higher) down to the point that you cannot even drive the car. I started halfway on the adjuster and it was almost tucking 14" basketweaves. Way too low for my uses. I raised it back up almost an inch and like it at that ride height.
    Rear - Not all that great. As many have said if you have a small bumper/late model car just running the rear spring should work out great. On an early model car don't even worry about trying it with the adjuster. There will be rear gap... with no adjuster. If you want to SLAM the car the fronts will be fine but you will want to get another rear spring for sure. Still if you need 2 rear springs at 180-200 dollars plus 420... the pricing is not bad.
    Now to the downside here. Fronts are difficult to adjust. Why? With the lower rear spring perch and the shock installed up into the strut tower there is not much room to work. This is where the quality level comes into play. It is easy to damage and mar up the adjusting collar with the tool provided. It took a good amount of time and effort to raise the front. Worth it in the end. The other issue and one you will want to watch out for is the threaded collar we discussed before that holds in the shock? Well it can and will start to back out as you adjust up. It would be best to get the ride height set out of the car... to not deal with this. If it loosens you will have clunks as the shock moves inside the housing. Fair warning.
    Ride Quality
    - This was the most surprising thing. It is quite good. I will say that just pushing down side by side with an IE3/Bilstein Sport car the JOMs are stiffer with what seems like higher initial valving on the shocks. Over rough terrain it is a little bouncy but hard to complain all things considered. I was super happy with the ride quality. Most surprising thing was the ride quality... and everyone that rides and drives the car comments on this.
    Performance - It's better than stock. It's not better than IE3/Bilstein sport or other performance setups. I have driven my previous E30 on IE3/Bilstein Sport and then custom Ground Controls. Both were more confidence inspiring. These you learn on them and they stiffen up and you power through the corner. Are they bad? No. Are they great? No.
    Final Thoughts - This setup is awesome when you consider the price, adjust-ability and what you receive. If you are looking for adjustable ride height on your daily driven that you like to toss around I would have no issue recommending this setup. It is great for that. I am 100% happy that I tested them out and a local friend of mine is purchasing them(along with my eBay camber plates I purchased). I am going to tuck my exhaust more and then run some custom coilovers. Since performance was what I was seeking first and foremost I want to run on something I know the results of and don't want to be messing with suspension.
    Verdict? Daily Driver that you want to lower the car? Enjoy... I did :)
    Pictures - Installation first two. 2nd is ride height with no rear adjuster or spring pads. Keep in mind that I did some poor math and went with 205.50.15 and my tires are quite a bit smaller than stock. With the 14" basketweave there was a MUCH smaller gap in the back.
    Beast mode review! Thanks for the detail and pictures. Glad everything was to your satisfaction!
    1991 e30 328i M52 swapped: Gone
    1995 e34 540i/6 1 of 76 Clean
    1985 e28 euro 525i the daily
      No problem :)
        i concur with this man.
        -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
        -The Beauty in the Tragedy-
        MECHANIC SMASH!!- (you all know you do it)
        Got Drop?? ;-)
        But of course
        E30s are know to be notoriously really really really ridiculously good looking
          Good review. Answered many of the questions I had about this setup.
            Thanks for the review! So in your finished height picture, is that as low as the rear can go?
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
              Yes. Keep in mind though I put on undersized tires. Some poor calculations on my end. Also it's an 87 so I have higher arches. Late model with proper sized tires it would look much better.
                I just wanted to clear that up for anyone looking. Looks like a steller deal for people that cannot afford expensive GC setups.
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                  Yup.
                  Keep in mind you would normally use your stock upper strut mounts. I put camber plates on mine.
                    I have a set of RD springs.....in your opinion.....paired with new sport billies....which would be the better set-up on a 318is???
                      Not sure. Never ridden or driven on the RD Springs.
                        This is a few days late but I autocrossed my car on these on Sunday. I have the 'vert kit with aftermarket camber plates and loved them. The car really stayed flat through the corners and wasn't bouncy at all. The only problem is there was a bit of wheel hop which I am assuming is due to the shocks not being stiff enough. Also, the rear didn't seem as it should be when you consider how stiff the fronts are. So some time down the road I MIGHT replace the shocks and get new rear springs.
                        However, since the point of these coils are more for going low and better, not best, performance. These are great, especially for the money. If you are buying these solely for track performance, there are better options out there. If you want to drive your daily driver to the track and have a comfortable ride home, these are awesome.
                        -Alex
                          I am in 100% agreement and the same set up on a sedan.
                            I have it on a sedan too. But now that I think about it, the 'wheel hop' I got could have been the product of having 500 front springs and 300 rear. So I'm definitely going to be buying some new springs for the rear and report back after some track days.
                            -Alex
                              doesn't wheel hop have to do with ratio of springs rates and softer tires?
                              2014 Alpine White 335i MSport
                              (Daily Driver)
                              Full Mperformance Aero
                              KW V2 Coilovers
                              VRSF Catless Downpipes
