Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Garagistic X-Brace
    It's solidly on there. I'm not sure what it would rip off. It's getting taken off though. Don't want to find out.
      Just ordered my second one of these. I had to sell the first one due to the gussets interfering with my swaybar. Looking forward to reinstalling along with a strut bar. 30% for a few days guys!
        It does hang a bit low, I always scrape speedbumps. All. The. Time.
          I've got one on my convertible now, I consider it a must have as it definitely reduces the scuttle/cowl shake around 50-60mph. That said, I am at stock height, so ground clearance is not a factor that I really have to consider.
          drvn2wn
            installed on my vert as well. incredible.
            HOWTOs:
            DB vert plastic bumpers
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
              Originally posted by lukeADE335i View Post
              Looking at your front on shot there, I'd be concerned with how low the x-brace hangs. The e30 sump is already vulnerable in lowered cars, and it looks a good inch lower than the sump?
              I bought one of these and when I saw this during installation I didn't even bother finishing putting it on. My car already bottoms out enough as it is.
              Bryan - 1989 325i S50 swapped /1990 Audi Coupe Quattro
                If your used to driving lowered cars it isn't horrible, but be cautious of high spots on pavement. If you see a high spot on the road just drive around it, don't try and be a hero by centering your car perfectly thinking you won't feel anything cause you will when your oil pan or X brace strikes the debris on street. That's how you break oil pans. It's always in the back of my mind while driving, I'm running Ground Control coilovers.
                Edit; Few pics. Here's a iPhone 7 on it's side and a pic of my ride height. The X Brace is somewhat parallel with your front wheels, so in other words when your moving slowly over a speed bump, as soon as the front wheels start to travel up/over the speed bump, your X Brace also travels upward and away from the bump. The issue is when you don't go over the bump with your front wheels and try and center the car so the front/rear wheels avoid the bump completely. The brace hang's low enough to which you might scrape. Hope you guys get what I'm saying.
                Lastly, I'm not using the spacers pictured on page 2, second pic "Haystack" posted. They're optional and if removed bring the X Brace up about half a inch. I also used all the factory hardware cause mine wasn't included with any.
                IMG_7747 by Kevin O'Brien, on Flickr
                IMG_7746 by Kevin O'Brien, on Flickr
Name:	Screen Shot 2018-06-13 at 6.58.40 PM.jpg
                1992 e34 Touring- Currently Building.. S50 Swap
                1995 e36 M3 Mugello Red - S50
                1991
                  [ATTACH]121843[/ATTACH]
                  Stock front swa bar? I have a thicker UUC front sway and without the spacers it was a bit too close for my liking.
                    Yup just a stock convertible sway bar here, I can see why you had to use the spacers then.
                    1991
                      Here's my review of the recent brace purchase. I ordered during their sale a monthish ago and I guess they got a ton of orders because I didn't get my brace for just shy of a month. They did answer questions quickly and professionally though. :up:
                      Came well packaged and none of the powdercoat was damaged. Seems like a VERY quality piece.
                      Installation, as others noted, can be a little fiddly. All the mounting points are slotted, but they are TIGHT. I had to use a jack at a couple points to get the bolt holes to line up enough to tighten with fingers at least 2 or 3 full turns. I've stripped out CAB lollipop mount holes before and while helicoiling is an option... I would like to avoid if possible. I did not use any of the included hardware. I re-used the factory stuff with no issues. The included hardware just seemed way too long, especially since I did not use the spacers.
                      This should give you an idea of clearance. It sits low, but I've only hit it once on a speed bump. Mostly because I am still getting used to it being there. Gone over many speed bumps but the only problem children are the tall and short variety. And even those clear if I go slow enough to not compress the springs on the other side. The longer/wider ones seem to have no problem clearing.
                      They clear my cheap ebay long tube headers easily so I have no negatives to report really. Extremely pleased with the purchase and really helped with the chassis flex of the vert. As mentioned, much quieter now in terms of chassis movement and twist. I am running on H&R sports with billy HD's and couldn't be happier. Will be purchasing their strut tower bar... and further in the future their reinforced subframe and maybe front sway bar.
                      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                      91 318is Turbo Sold
                      87 325 Daily driver Sold
                      06 4.8is X5
                      06 Mtec X3
                      05 4.4i X5 Sold
                      92 325ic Sold & Re-purchased
                      90 325i Sold
                      97 328is Sold
                      01 323ci Sold
                      92 325i Sold
                      83 528e Totaled
                      98 328i Sold
                      93 325i Sold
                        I have a question about these. Are the x brace hardware bolts long enough to go through the e36 rack spacers and bolt on the other end? Also... Since you have to take off the FCAB lollipops, dont you need to get an alignment after installing this? I would hate to do an alignment again after installing this - it costs 300+ for alignment on this eccectric bolt GC coilovered e30.
                          ^I'm not sure why you would have to. The FCAB lollipops are not adjustable and the alignment sleeves on the chassis pretty much lock them into place. I did not get mine realigned.
                          91 318is Turbo Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                            Yes the bolts will be long enough. No because the front control arm bushings/ brackets are keyed, they only fit one way.
                            1991
                              Btw these are on sale for black friday. We still got a few left in stock in various colors. Red, blue, black and green.
