Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Eastwood 2k Aerosol sprays
    I tried this to paint my re-worked trailing arms and subframe. Powdercoating was fancier than what I wanted, but I didn't want Krylon, either.
    The Eastwood 2k sprays are about $20 and are true catalyzed paints, more like epoxy than paint. It sprays nice and is tough as nails. It looks identical to the factory finish.
    You do need a respirator to spray it. Highly recommend!
    Interesting option for when I have my subframe out in the spring. In August I did a ton of rust repair to the floors and front end of my e30 using Eastwood's products, namely the rust encapsulator, internal frame coating, and rubberized undercoat. Seems like good stuff. Used the 2k primer to paint my valence as well, then sprayed over it with color matched cans from a local shop.
    Eastwood's is expensive as heck but for most applications it seems worth it.
    Sent from my moto g(6) using Tapatalk
    (OO=[][]=OO) For Life
      I've used their clear before, and once you wet sand and polish, it's about as durable as professional job. But like anything paint related - prep is the key.
      1984 Alpina B6 2.8/1 #35
      1991 Racecar (Chase Schmidt's former drift car - M30)
      2006 BMW X3
