Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Shadowline Motorsport - LED Bulbs & Accessories
    Originally posted by djmossm42 View Post
    I was going to try them this weekend but didn't have time. They should fit ok, you just need to figure your cable management (probably zip ties) to keep the driver/ballast from hanging down. The braided heatsink will keep whatever form you put it in so you can bend it up around the fog light housing. I will test fit one tonight and take pics. I have late model fogs, so the bulb installs from the bottom. Not sure about the positioning of early model bulb but you should still be able to find a way to mount these bulbs securely.
    Sent from my MI 4LTE using Tapatalk
    Very quick response. I have late model fogs as well. But have 4300k HID ellipsoids. When i switched on my fogs last night. They provided almost no extra light.
      Do you have the OEM fogs? My suspicion is the fog light design is a bit of the problem, but I've seen very bright ones before but not sure if they were modified. What type of light source are you using in the fogs?
      These bulbs are very bright so it should be very noticeable. I had SilverStar halogens in mine and they provided light but it was hard to tell, the main reason I could tell was because of the yellow lenses but the intensity did not match my headlights when I had 2400lm/led bulbs.
      Wheelwell
      Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
      LED Bulb Thread
      R6 LED Review
        Oem fogs and prob very old bulbs.
          This is just what I've been waiting for. I'll want two sets of H1 for my depo smileys. Just one thing: can you post a pic of the distribution pattern? Ie your e30 facing a wall at night time. So I can see the cutoff pattern and compare it to mine
          Thanks!
            Thanks!
            Ive wanted to see the same thing. LED typically have a very tight and focused beam with limited spread.
              Thanks!
              This was the best I could do, it doesn't get dark till 8:30/9pm now.
              Please keep in mind there are some limitations in the depo design. Mainly the cutoff shield being flat vs curved. Curved shields help keep the line sharp across the full width of the beam. You can also tell in the video the focus is not infinite. As the car gets closer the cutoff sharpness increases significantly and when moving back it decreases. Another possible flaw is the lens and whether or not it is optically clear. The high output of these bulbs helps overcome some of the limitations in the optics and there are no major dark spots that I can notice.
              I plan on addressing these things and possibly create an upgrade kit as an alternative to a full retrofit.
              https://vimeo.com/171515592
              Here's another pic on a gray/light blue wall in low light
              Wheelwell
              LED Bulb Thread
              R6 LED Review
                Yeah you will see a big difference with these. I will do the test fit in the morning, stay tuned.
                Wheelwell
                LED Bulb Thread
                R6 LED Review
                  That would be awesome. I would rather spend money on LEDs over HIDs
                    Only a few days left before this first round closes!
                    Did a quick test fit in the late model fogs this morning.
                    Notes:
                    1. You can't use the cover but the bulbs have a very high water/dust proof rating.
                    2. I removed the ground lead to the mounting chassis inside the housing and connected the wires directly to the internal prongs. You can still use the standard connector this way (no splicing)
                    3. The heatsink can be bent up well out of the way. Also I don't have a lip on my car.
                    4. The bulbs are 6000k/4800LM and the fogs have yellow lenses.
                    Wheelwell
                    LED Bulb Thread
                    R6 LED Review
                      Wow. Thats freaking bright for a fog light.
                      I don't even own this car anymore, but I'm too lazy to change the picture.
                        Those fogs are stupid bright, wow.
                          Yes, these are no joke! If you think it's too bright the 5000K option might be just right @ 3600lm
                          Wheelwell
                          LED Bulb Thread
                          R6 LED Review
                            Some may be wondering if the headlight back covers fit?
                            They fit perfectly!
                            You just need to bend the braided heatsink forward.
                            Have a great day!
                            Bryon
                            Wheelwell
                            LED Bulb Thread
                            R6 LED Review
                              Invoices have been sent to current participants, last day for round 1 is 6/27/16. Current price is $65/set!
                              Round 2 starts 7/1/16 @ $84.99
                              Wheelwell
                              LED Bulb Thread
                              R6 LED Review
                                Can you please explain how these can be plug and play? What about the radiating belts and LED drivers? I'm sure they won't fit inside the ellipsoid cap.
