m50 engine wiring harness color code
    I just got an e34 engine wiring harness for my 92' e36 engine,and cant figure out which connection goes to which sensor....does anyone know of a color code to sensor chart???
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    http://www.wedophones.com/BMWManualsLead.htm
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
      I was hoping to pull back the boots of the connectors,look at the color ,then match it with the sensor ...ie, crankshaft,camshaft,idle sensor,etc....anyone know the color code for a m50 wiring harness??
      NASA
      BMWCCA member
      PCA member 25yrs
      1997 M3 sedan
      2001 325CI DD
        Like he said ^
        Look in there for you car and engine, it'll list the wire colours for each sensor. Just have to do a bit of work.
        Cam .W '91 325is
        Spaz's 1991 Alpine White???? S52 Build Thread...
          Most of the connectors can only go to one thing. Is it vanos or NV?
          BNB Designs
          Richmond CA
          Julian 848-248-8029
            it is a non-vanos 92' and harness is from a 92'e34..has more connections than my e36 does (my e36 harness is shot..looks like wires melted at the ECU side) the e34 harness has 4 3pins and 4 2pins for the area under intake..i looked at http://www.wedophones.com/Manuals/BM...g%20Manual.pdf
            and only shows the pin # of related sensor to ecu
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
              i think i found what i was lookin' for
              NASA
              BMWCCA member
              PCA member 25yrs
              1997 M3 sedan
              2001 325CI DD
                There will be one more connection on the e34 harness - for the oil pan sensor. Possibly a traction control connector as well, as I believe more 5er's came with ASC+T then 3ers.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                  thanks..i got more connections than i know what to do with....but
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1997 M3 sedan
                  2001 325CI DD
                    bump. so i can save this and view it...
