My 11 year old Optima battery finally died. I was going to head out and get a new one and it dawned on me I had not researched the battery situation for a swap. So I have all my swap stuff, but the project is on hold for the moment. I figured I should keep in mind the swap and try and figure out what battery would be best for the swap.
First thing I did was check with my buddy down at Les Schwab and there are major differences between a battery for an s50 and an m20. The CCA and the RC are significantly higher and on top of that the battery itself is a lot bigger. So next I start searching around here and elsewhere to see what people are using and I am not finding much of anything.
And of course I have a vert with the battery in the engine bay. I started looking at some swap pics and I don't see any with the battery under the hood, but probably because most are in the trunk I guess. I am pretty sure all these are a vented type of battery. I know the leads from my swap motor end up at the current battery location, but were connected to a remote terminal in the car it came out of.
So a couple of questions. First, what are you guys running for a battery? Second, anyone know if I am going to have to relocate the battery?
