Markert Motor Works Dyno Thread (many inside)
    Originally posted by The Dark Side of Will View Post
    GM MAF's output a frequency proportional to airflow, giving them *FAR* better resolution and range than a 0-5V signal... switch to that system?
    how do you suggest doing that? reprogramming the DME from scratch? :p
    It's only a problem when the MAF is too small for the given airflow and the signal starts to max out. The MAF wouldn't be able to read higher anyway, even if it was frequency based. I'm not convinced it's really better regardless, BMW could easily use that system if they wanted to, but they've continued with a 5v signal instead. The resolution of the signal has more to do with the speed and quality of the ADC input than how many volts or what type of system it is, anyway.
      That was mostly a joke, I know it wouldn't be easy... BUUUUUT GM went to a 58x trigger wheel across the board in '05/'06ish ;-)
      The frequency signal isn't susceptible to corrosion in the contacts or the other ravages of age... and it just plain is more accurate across a wider range of signal ;-)
        Uh long time no update!
        Some FBO 335:
        Some FBO S52 E36 pre/post exhaust work:
        12PSI S52 VortechSC E36 Vert:
        M50 E34 bone stock, pre/post tune (OBD1):
        Remote Tuned 12:1 S54 pump gas (dislike new dynojet software):
        Check Us out on Facebook
        Full Product Line Tuning
          Some FBO 335:
          info on S52 exhaust
          E92 Msport
            Originally posted by TheAxiom View Post
            info on S52 exhaust
            Went from headers/stock midpipe to bigger headers merging to a 3". This is the culprit for the torque loss.
              Stock cams? Pullies/flywheel? Stock TB? 91 oct?
              Which headers, Turner Shorties?
              247whp without gutting the bottom end AND keeping cats is damn impressive. And tempting.
              2017 Chevrolet SS, 6MT
              95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
              98 M3/4/5 (stock)
                Schricks IIRC, originally stock headers/midpipe then to ebay headers and some 3" midsection. 93oct.
                  HOw close was that merger to the headers?
                  E92 Msport
                    4/27/16
                    E46 M3 VF SC 6psi IC kit. VF Tuned vs Our retune. VF apparently doesnt see the need to alter factory vanos maps as well as overfueling like hell. Also BOV or something is freaking out up top. Boost falls off at ~7500.
                    I'd be pissed if my m3 was fast until 7500 rpm then fell on its face!
                    -Christian
                    '37 Chevy pickup, the ├╝ber project
                      Can you tune a obd2 m52 turbo e30?
                        I @$$ume that a '96 non-Vanos M62 DME would be easier to tune than an OBDI M60/M62 DME.
                        Is this correct?
                          10/4/16 Update
                          Behind on this:
                          Stock E46 M3:
                          Single Turbo 335i, E85 Port Injection
                          Intake/Exhaust E92 M3:
                          Nearly Stock E92 335is
                          F10 M5 Jb4 Eisman DP's
                          F30 328i Jb4
                          AA HKS SC 8psi ZM3 Roadster. AA tune vs MMW tune
                            Also: 18.5PSI M50 manifold Ebayheader Cutring Stock CR S52 Vortech V1 T-Trim E85
                              AlsoX2:
                              S52 Mroadster progression
                              Stock tuned
                              M50 manifold tuned
                              M50 Manifold Ebay headers/exhaust Tuned
                              [IMG][/IMG]
                                Gained another 12 hp using some Chinese exhaust manifolds?
