Markert Motor Works Dyno Thread (many inside)
    Originally posted by M-technik-3 View Post
    Gained another 12 hp using some Chinese exhaust manifolds?
    And a full SS exhaust, don't recall the details on it.
    Check Us out on Facebook
    Full Product Line Tuning
      Well that seems to be a decent system. That is a good jump for what would most likely be under a grand.
        Tuned a rear mount single turbo E39 M5 at 7psi tapering to 4.
        Also tuned a E92 M3, was already tuned by someone.
          Can you work with old Motronic 1.7 (E30 318iS ECU)? I have a 2.1L built M42 and would really like to dial in the tune without having to go stand-alone!
          Transaction Feedback: LINK
            I have a little wild idea on how this might actually be possible. If you find an ECU and harness from an OBD2 E36 318i and swap it over, maybe Dave can flash it for you?
            Simon
            Current Cars:
            -1999 996.1 911 4/98 3.8L 6-Speed, 21st Century Beetle
            Make R3V Great Again -2020
              Where can I get Info on your pricing etc? I have m52 turbo swapped e30
                Give us a shout
                  Tuned a few S54 cars:
                  S54 Swap E36
                  Stock S54 E46 M SMG
                    Have you ever dyno'd a M52 with aftermarket (Shrick?) cams?
                    Simon
                    Current Cars:
                      What is a "good exhaust" according to you? Serious question.
                      E92 Msport
                        This thread needs a serious update
                          Please do. This is my favorite r3v thread. Keep them coming.
                            UPDATEEEEEEEEEEEEEEEEEEE
                            FBO OBD1 S50, Pre/post a competitors Off the shelf tune:
                            Stock E46 M3 with intake
                            M54 Swap E36Ti
                            Just kidding. That was fixing the Cam sensor. Shows you how much the vanos does!
                            After final Tune (again not all me :) )!
                            S52 with another persons tune pre/post
                            MS45 ZHP. Final run the clutch started letting go :(
                            E92 M3 DCT, Intake MS midpipes Mperf Exhaust
                            Supercharged non IC 95 M3
                            M54 Swap
                            E90 325i Progressions
                            E93 M3 All stock
                            Stock E46 M
                            S54 Swap E36
                              Why Do the images randomly end up huge :(
                                I love this thread. I literally spend hours looking at these. Please keep them coming :) The more details the better!
                                e30 restoration and V8 swap
                                24 Hours of Lemons e30 build
