Markert Motor Works Dyno Thread (many inside)
    What is up with your E90 325i? The 3 stage tune doesn't seem to account for all the DISA valves...otherwise good stuff as always.
    E92 Msport
      it's definitely a 3-stage based file - I helped him set it up. IIRC the car is a high miles automatic.
        If that's an automatic, that's even more impressive.
        E92 Msport
          6AT with 238k miles :)
          Check Us out on Facebook
          Full Product Line Tuning
            Dang I was about to be really sad before I saw the post-cam sensor fix run on the m54 Ti. Mine feels about like the first graph though
            - '88 m54 coupe
            <3
              Wait a second, I know whose car this is. It looks like it's running transmission software (hence the ability to hold gears and a higher red line) You're in GA - so maybe someone from Bimmer Geeks.
              Don't ask me how I knew, but it just hit me.
              Impressive stuff.
              E92 Msport
                Different cars - I don't think he has a 6at flash but we'll have to fix that. :)
                  He does I believe, but this looks like good stuff. No valvetronic limiter, 4 stage DISA disabled, proper DISA set points. Good work - now test out those lift adjusters.
                  E92 Msport
                    I don't have a trans flash. Different car ;)
                    You can hold gears to redline on stock flash just fine if you hold the shifter or paddle. It will even bounce off limiter
                      ON the 3 stage dyno, what's the reason for no first stage DISA activation? You can see it's present in the first dyno (Pre) but not after you tune.
                      E92 Msport
                        One of them codes occasionally. Prob that one. Plumbers always have leaky pipes.
                          sent you guys an email about reflashing my 02' M coupe Clownshoe....Has a Shark tune on it, but it sucks ass, and the car isnt running right
                          91' 318iS - S54/6MT Swapped
                          08' E90 M3 6MT - Daily
                          Originally posted by IronJoe
                          Originally posted by 2mAn
                            Dave you guys offer remote tuning correct?
                              Tuned a modded High comp stock cam 2.5L M20 was running 98 octane
                              How high was the compression on this? Thats pretty damn impressive
                              Simon
                              Current Car:
                              -2017 i3 REx, 21st Century E30
                              -1975 Alfa Romeo Giulia Nuova Super 1300, the never-ending name & project
                              Make R3V Great Again -2020
                                High enough to use 98 octane which smells so great. 12.5:1 I'm gonna guess.
