Markert Motor Works Dyno Thread (many inside)
    Yes, I did a bad job making my exhaust. I think I am going to build something like the Bimmerworld race exhaust next so I can at least keep one of my mufflers
    - '88 m54 coupe
    <3
      You could leave the axle back portion 3.5", making the first section smaller is going to make the biggest difference.
        It would be nice to tone it down a notch...
        Lorin
        The M30 is God's engine.
          i wouldnt copy bw, just build your own
            Originally posted by digger View Post
            if you put the y-pipe that merges to 3.5" in the right spot you dont lose the bottom end anywhere near as much. seems to be more about length than size in this area of the exhaust.
            http://www.m3forum.net/m3forum/showp...&postcount=961
            just maintain the twin secondaries (collector) far enough before using a Y or X and you'll be sweet
            Correct. The merge is very important, and that's what ruins most s54 exhausts.
            This. BW's exhaust still has consistent dynos showing poor bottom end torque, their merge is too close to the headers.
            INSTAGRAM: @UNDR8D_EMPIRE
              Another E46M3, this one bone stock. 125k on the clock...
              Progression:
              Also Tuned a WAR Chiped OBD1 S50. Ended up ripping out war chip and just throwing a regular 413/chip in there when all was said and done. Car had nice headers/midsection, intake and stock other than that.
              Check Us out on Facebook
              Full Product Line Tuning
                Originally posted by 328ijunkie View Post
                ...Ended up ripping out war chip and just throwing a regular 413/chip in there...
                Told 'ya so. ;) :p
                john@m20guru.com
                Links:
                  wow.. the installer of that WAR chip must have wired it wrong. ;)
                    Dave hit me up about the WAR, and just happened the day before I ripped one out of a turbo m20 e30 and put in MS. I got fed up with it as well.
                    john@m20guru.com
                    Links:
                      Whoa that's a funkkkky graph
                      nice numbers on the m3!
                        246 from a OBD1 S50??? color me intrigued.......
                        Any details on it?
                          Just had generic Intake/3.5MAF/24lb injectors (Stock cams) some nice headers and exhaust.
                            To continue S54 Exhaust Discussion:
                            Stock S54 E46 M3 vs JB's S54 E30
                            Also ironically: BW race Exhaust car (and highest ive ever dyno tuned) vs JB's E30 S54:
                              man, don't make him feel bad about it! lol
                              but, 344whp is insane. let's presume that the drivetrain loss % decreases as HP goes up (because it's not linear). if it were 10% instead of 15%, that's still 382bhp from 3.2 liters!
                                I was simply showing the coorelation in exhausts and low end torque....
