Oil level sensor connector
    So my s52 wiring harness didn't include an oil level sensor 3 prong connnector. Do you guys know where I can buy one and how I should wire it into my harness?
    You can chop off the oil level sensor off an E30 harness. Worked for me.
    I used this thread to help with the wiring.
    http://www.r3vlimited.com/board/showthread.php?t=143507
      What if I don't have an e30 harness?
        http://www.partsgeek.com/gbproducts/...FYc8aQodF60Avw
        Would this work for the oil sensor? Basically a three prong connector with three wires.
          you could use a 3 prong weatherpack connector. that's what I did.
          Shadetree30
            If there is a parts yard nearby, go cut it off of a 5-series. I ran two new wires (the third I tied into the other grounds) through my S50 harness for an OEM look. Then I simply connected them to the correct E30 wires through the C101. I also added a couple new wires at the same time, again routing them through the C101, for oil temperature and pressure senders.
