E30 S54 Swap AC signal input to DME
    CEL is triggered via CAN, so you need to wire up the CAN adapter.
      Thanks!
      Euro Delivery Thread///E30 Project Klaus
        For future reference on the Gen 1 board here is a complete wiring so that the DME controls the aux fan fully based on Temp, A/C pressure, Speed etc:\
          And for Gen 2:
            I sold one of Garry's CAN controllers to someone who hasn't been able to get the A/C compressor to turn on. He says he has everything connected properly and Garry has even replaced the CAN controller for him and it's still not working for him. He says he's receiving the following error: "DME signal error CAN bus instrument cluster"
            I'm not sure exactly how the controller functions. I just do the wiring and offer the controller as a courtesy with my harnesses. Does anyone have any ideas as to what the issue could be? His car is a 1999 M3 with an M54 swap.
            Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
              That error doesn't mean anything other than his swap flash didn't suppress it. The CAN board doesn't emulate all cluster messages because it doesn't need to and some need a partial VIN.
              He is in touch with me to sort things out.
                ... He says he's receiving the following error: "DME signal error CAN bus instrument cluster"...
                FYI, the files I gave you have a subcategory in the DTC XDFs for DTCs to suppress, so that you can do that with your EWS delete. I am willing to walk through the usage with you remotely.
                  Did you intend to quote someone else? I didn't do his swap flash.
                    Awesome thanks! I didn’t do his swap flash either.
                      hi, how does one go about purchasing one of these units
