M52TU Swap help!
    M52TU Swap help!
    Hey guys! I am currently doing the m52tu swap. I have put my e34 oil pan on it and the power steering pump inlet hose fouls it. What are my best options of getting around this? Also, wondering if a e38 ms42 loom will work and reach the proper ECU location correctly. Any help is appreciated. Cheers
    running into the same issue . you need a late model m54 power steering pump. the return hose is more at an angle and clears it . gotta get it used with the brackets. it is the one with the aluminum bracket on the front like this one.https://www.ebay.com/itm/03-06-BMW-E...Condition=3000
    edit: just looked into it again and these guys don't have a problem with it even though the have the one with the metal bracket. https://www.flickr.com/photos/blackk...i/35753926440/
      Is the pump you need
        Originally posted by drum4fun27302 View Post
        32411097149
        Thanks for the reply man. What engine and model BMW did this pump come from? And will I need the bracket with it?
          it's off an E39. yes , the brackets are needed because that is what different between them. pump are the same, brackets are different. Just bought a used one en ebay for $45
            Weight:1986.450 kg
            Price:$507.95
            Part 32411097149 was found on the following vehicles:
            5' E39   (02/1995 — 12/2003)
            Realoem is very useful.
            Not sure I believe the weight figure, tho!
            t
              Do you have a part number for the bracket?
