24V AWD Swap Knowledge Base
This is a sticky topic.
    the E46 rack has better clearance for the front diff but the subframe needs modified for it to fit.
      Originally posted by nando View Post
      nice!
      I was going to give up on it, but after going back and forth between my E90 and the ix, I'm definitely going to try and make the E46 rack work. The E30 steers like a bus in comparison to the E90. my 385mm Mtech-II wheel doesn't help either.
      I have an E46 Xi rack, so I can include mounts for it and at least try to make sure it clears everything else that bolts to the crossmember.
        Ok thanks, that will have to wait for next year i think :)
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
          3mm clearence between brake rotor and tie rod should be ok?
            yes, thats probably what it is from the factory.
            Gigitty Gigitty!!!!
              Great, didn't measure stock setup :)
              Now its time for caliper adapters!
                Nisse, start a build thread already!!
                1990 Brilliantrot 325iS Build Thread
                  are those m3 rotors?
                    i don't know what he has in the pic, but e36 m3 rotors work perfectly on e34 ix hubs.
                    Gigitty Gigitty!!!!
                      Maybe, but the project is so slow at the moment so everyone that reads it will fall asleep :D
                      No, Jaguar :)
                      Ok, then the E34ix hubs must be a little wider because theese rotors are 3mm shorter than M3 E36 :)
                      Sorry for the slightly over sized picture btw haha :D
                        What year & model Jaguar?
                          XK 8 Coupe (QEV) 03/96 - 12/06 and XJ (NAW, NBW) 07/97 - 05/03
                            Thanks!
                            That will be really handy info for figuring out a bolt-together 5-lug swap. Those are your E34 hubs, right?
                              Thanks!
                              Nope, E87 :)
                                Nope, E87 :)
                                Good to know!
