24V AWD Swap Knowledge Base
This is a sticky topic.
    Looks good man! :D Wow the TC is really big! Or wide maybe!
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
      Originally posted by packratbimmer View Post
      Impressive work man! Clearly nothing will hold you back...
      Curious - What differential ratios are available with your set up? Does the front differential use a 168MM ring and pinion?
      I'm not 100% about the ring and pinion as ETK says typ165 if I remember correctly. I'm believe other 168mm ring and pinion could be used with some amount of machining.. I think I'll go with the 3.38:1 which it has stock. Not ideal for my aplication, but I don't want to modify everything at the same time. Hoping to drive next summer. :D
      With this gearing I must change to 5th gear right at the end of 1/4mile so that's not good.., but I may end up using the 7 speed DCT gearbox at somepoint and then the gearing is OK again (fast shift times).
      TC is really wide and hangs low, but it is also very short. I have to lenghten the rear driveshaft for ~10-15cm.
        Tranny brace/mount arm
        I am also doing a 6 speed conversion mated to M50, where did you source that black tranny/transfer case mounting arm?
          It's custom made for this application.
          Btw. Sold the gearbox in the pictures and ordered a DCT gearbox from 2010 e93 335i. ;D
            The pics don't work for me.
            AWD > RWD
              Well then, that's just drooool
                Here is my process... Tying up odds and ends
                Sent from my SAMSUNG-SM-N930A using Tapatalk
                    Tranny in place, needs custom mount, rear drive shaft shortened, front drive shaft lengthened
                      Nice swap, any more info about the trans? Like what you did to it or how its mounted to the TC
                      BTW, nice shoe!
                      My Garage
                      Feedback
                      Instagram: Stone.Hopkins
                        haha thanks the shoe fits very well, the trans is from 540i, mated with custom bell housing/spliced, actually welded on, clutch from e46 M3. The rear of tranny has adapter machined to fit and also welded on and thus TC bolted onto it. I will provide specific pics of this, but boy I gotta figure out how to reduce size of the pics lol
                          She fired up!! So a few things specific to AWD 24V swap.
                          1. Frankestein pan, is the easiest way if you ask me as many shops weld aluminium these days, your angle thus will not allow a brake booster smaller than Porsche fit there, the steering wheel assy is too high. And you use your current motor mounts.
                          2. Any driveshaft/line shot will shorten and lengthen your shafts as you wish, I was charged $79.
                          3. Please, ANYONE has to use a new CPS otherwise they should be banned before posting and asking about no start issues. Honestly I went through tons of search post, I went back and changed the CPS to a just a used one and it fired right up, I mean first kick. So that measuring of resistance on the CPS is just not reliable and emperic. I can imagine how much sorrow and money has been dumped on this issue.
                          4. Good luck all.
                            so you are using a getrag 420? you gotta post pics of all this!
                            get a membership to imageshack. download your pics on there. it will reduce them to what ever size you want. select "post in forum". copy the link and paste on this thread.
                            send me a pm if you need more help.
                            Gigitty Gigitty!!!!
                              Hi dudes I read the entire thread, really amazing work done so far :up:
                              I'm thinking about an ix build but have questions.
                              Will this constellation work?
                              M50 engine (of course)
                              E34 transmission (cause of the gearing)
                              E34 trans case (to control it manual like nisse)
                              E34 front diff (cause stronger and taller/longer ratio)
                              Wich Shatfts??? E34 I guess
                              Frankenpan (to let the engine in stock position.
                              from what I see the m50 pan has the pickup/mounting for the front diff more foreward than the m20 pan wich causes interference with steeringrack and crossmember. Will it work to cut off the hole diff pickup and weld it more backwords to m20 spec, to have more space to let the engine in stock position rather than cutting and smashing the firewall?
                              Another question is: Will the e34 transfercase bolt on the e30 transmission?
                              I think the easiest way to swap is all e30 parts except frankenpan. Then we have to live with m20 spec tilted engine wich causes interference with brakebooster and theres downside like weak front diff. Now days the diffs getting rare.
                              I hope to get answers here.
                              Cheers Kurt66
                                if you're using the E34 trans, transfercase, and diff, just use the E34 oil pan too. It all fits together.
