325ix Rebuild-able Viscous Coupling
    Originally posted by The Red Baron View Post
    I'm all ears for results. Also could you let us know where you got your silicone fluids from? I'd like to service a few of mine soon. But wanted to get some good advice before attempting. I have machines to use, but not exactly sure what fluid was intended, and the best place to get it. Itd be nice to know your procedure in cleaning out the original vc parts and fluid as well.
    believe it or not, you can just buy it on amazon. the car originally had 80,000cst fluid in the vc. no one sells that but you can buy 60k and 100k and mix them. i did that once, but i think just buying 100k fluid to be done with it is the way to go. you will have in theory 20% more lock up.
    here is the link
    https://www.amazon.com/Silicone-High.../dp/B00Z78H0CQ
    Gigitty Gigitty!!!!
      here is the link
      Or you could put less 100k fluid into it and have the same performance with a greater margin against heat damage.
        Possibly. I’m not too sure it works that way though
        Gigitty Gigitty!!!!
          hey, can you post the CAD files to machine one myself? :) in case i find a manual geabox with transfer case to work on :D
            So any updates, has this work in the car...??
            :coolphoto:
