If you sand the anodization off the bumper, it will require exponentially more cleaning and polishing once you do. The best solution I've found is the deoxidizer product from Classic Trimcoat. There should be some pics in my build thread.
Polishing bumpers how to?
If you don't like sanding, do not attempt this. I've heard it takes 80 grit to remove the anodized finish and you will have to sand with progressively finer paper, removing all sanding marks before you can polish. It's a very time consuming project and if you don't take the time to do it correctly the results will be less than satisfactory.Comment
Oven cleaner works well to remove anodizing in most cases, you may have to play with the times a little, could take 5 min could take 2 hours. I have had good luck with easy off in the yellow can on some bike parts in the past. Don't panic if the aluminum starts turning a dark color, this wipes right off with CLR.Comment
Interesting. I tried several metal polishes and like someone above said, it only did so much. Looked good from a viewers distance but up close it still wasnt perfect. I ended up painting them...sometimes i feel like finding another set of 88 bumpers and getting the chromed...hmm. Waiting for some pics :)
V8e30.. Looks great man! I was afraid you would run into that problem with the oven cleaner, like pare said it is very thick on those bumpers, i have only ever used it (succesfully) on bicycle parts.
If you use more varied grits of sand paper between 400 and 2000, youll get even better results. It is very hard to get out the 400 scratches with 2000, in the least use 400, 800, 1500, 2000. Always be sure to clean your bucket and start with fresh water when changing grit..
Looking forward to pics on the car,Comment
DREWLIENTE
