did a quick search nothing big came up so i decided to make one.
how and what is the best way to polish early model bumpers if anyone has done this post pictures of after and what steps that took to make it happen.
thanks guys :up:
So here is how i did it.
step one DONT USE THE OVEN CLEANER!!!!!!!
this stuff
or this will happen
not sure if it is corrosion or what... but it was hard to get off.....
any way the way i did it was good old fashion ELBOW GREASE!!
HERE IS WHAT YOU WILL NEED
and about 2 hours of time per bumper.
step one
wet sand with 400 grit sandpaper until uniform on all surfaces wished to be polished.
step two
wet sand with 2000 grit sandpaper this takes quite some time so just chill and use some elbow grease and sand away.
step three
polish away with you polishing compound, i used white diamond polish it has a sealer after it dries to protect the shine but i will still use wax to seal it again.
the after
it still needs to be polished one or two more times to be like chrome has mini micro scratches if you look at it just right. this is just one time hand polish.
thanks guys :up:
this stuff
or this will happen
step one
step two
step three
the after
DREWLIENTE
