True e36 one touch windows DIY
This is a sticky topic.
    Originally posted by SoEm0 View Post
    Awesome write up. I am going to start looking for the stuff needed. Just a few quick questions.
    a. where is the module located in the e36?
    b. where did you stash it when you finished installing in the e30?
    c. can the module control 2 windows and the sunroof? If so what else would need to be done to make the sunroof one work too?
    the E36 is located under the dash behind the glove box, but i didn't use the E36 module since it doesn't really control everything, i think most just express the driver side both ways, the best thing would be to buy a module like the one i have in the pictures, made by AutoLoc i think, not that expensive anyways.
    and they all fit under the ebrake console right behind the center console, also you need a module for each window and one for the sunroof
    Sticky:True e36 one touch windows DIY
    1990 M3
    1992 Mtech (S50 + 5 Lug)
      wow this is awesome. sticky this now
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
        You can also use the e38/39 switchs - the leads you need to cut are much easier to get to and the switches themselves look much better IMHO
        PS: I believe this is the unit he is using:
        http://www.amazon.com/AutoLoc-WC1000...1107952&sr=8-1
        CHEAP REBUILT INJECTORS
        Need Quality Brakes? BimmerBrakes has it!
        For anything Else go with BluntTech!
          nice work! thank you.
            What are they waiting to make this post a sticky? Thanks for updating pics with arrows.
              Originally posted by 5Toes View Post
              Sticky... now
              :D
              i'll give them a try once i get my hands on a set, i just happened to have the E36 ones from the M3 i'm parting out. and yes thats the module, Thanks for the link.
              1990 M3
                Ygpm.
                  Ygpm.
                  good stuff, Thanks
                  1990 M3
                    Dude...this is unreal.
                    I have been futzing around with my E36 switches for a LONG time, never even thought about modding the switch!
                    You, my man, are brilliant!
                    That is basically the same module I use, but I get mine from directly the manufacturer, Scytek (the US distributor some Taiwanese company), but theirs also has an "auto vent" if it hits 100 degrees in the car...very solid and reliable unit IMO.
                    Great job, man!
                    Closing SOON!
                    Thanks for 10 years of fun!
                      Great job, man!
                      Thanks and i'm glad i can help, this forum saved my ass so many times and this is the least i could do, too bad i never document my work, but from now and on i'll document it and share it with you guys.
                      ps i've seen your work around here, pretty impressive stuff you make
                      Yanal
                      1990 M3
                        Nice work!
                        My 1989 e30 s52 Touring... this is Betty
                        My 1989 325i vert (sold)...this is Nina
                        My 1991 M5 (sold)... this is Veronica
                        Photo comparison: OEM vs aftermarket windscreen for a convertible
                          Wicked :) Will have to do this one day when $$$ and time allows
                            that is incredible post up!! hey luke, link to the auto tilt feature? is there ones that have lower temp props?
                              Yanal,
                              Oddly enough, I have never seen the link to the window modules on Scytek.net...but they should be there, right? They are the only alarm I would ever consider using these days, personally. But their window modules don't seem to be on their site. They make two modules, a two-window and a four-window. The two-window module will control one window up and down; the four-window will control two windows up and down, but does not have separate activation wires for each side.
                              I will be installing your mod in my car very soon. I currently use E36 small green base switches and SPDT relays in conjunction with those window modules, and I'm looking forward to doing your mod...as soon as I get another car (since I wrecked this one).
                              Luke
                              Closing SOON!
                                Luke,
                                Sorry about your E30, hopefully you'll get your hands on another one pretty soon, life sucks without them I know, also you don't need extra relays, use the ones that are already on the board like I did, and non of the one touch window module came with extra wires, you have to solder these yourself, shoot me a picture of the front and the back of the board and I'll tell you exactly where to solder these wires.
                                Yanal
                                1990 M3
