The Cabrio Suspension Thread
This is a sticky topic.
    What is the best strut brace and subframe brace for a 1990 (89 build) 325i vert? Garagistic?
      The "best" might be Mason engineering for both. I have the Mason X brace. I think the Sparco knockoffs such as the one from Ireland engineering are good too and cheaper. If you go with the Sparco style make sure to use the added hole to secure it to the strut tower. Most people don't seem to use that hole to bolt it to the tower but it is there for a reason. It requires drilling a hole in each tower. Without making tbe brace as functional as possible it's really there for bling purposes.
        Am i reading correctly that Mason engineering you can use their cross brace with their skid plate? wonder how hard it would to make it fit an 24v swap pan...
          From reading this long thread it appears that the set up for the E30 Vert is the H&R Cabrio Springs and Billie Sports?
            I've been digging and digging because I'm trying to refresh mine. People like the Billie Sports, but have a "rough ride" to them. It's tough to gauge what "rough" means or feels but I can't imagine it to be pelvic crushing uncomfortable.
            My current setup from PO:
            Front:
            Unknown strut inserts
            H&R Lowering Springs
            Rear:
            Billie HD's
            COMFORT: 3/5 Not cushy, but soaks bumps up well. Bottoms out on big bumps
            Handling: 4/5 Very predictable and handles on Northern California twisties. I can drive with confidence knowing what the car wants to do.
            Loved coilovers on my last car but I ain't about the cracked oil pan life as I want to participate in rallies. I think I'm leaning towards Koni SA's?
            IMG_7862 by lorenze torres, on Flickr\
            CURRENTLY ON 16x8/ 16x8.5 Gotti's
              Lots of people find BS to be "harsh" and I dont think Ive ever seen a post that says "Konis compromise handling".
              Must mean something
              Alice the Time Capsule
                Must mean something
                There's my answer right there!
                So the question now, is what part numbers do I purchase or is it pretty universal as long as I don't get the ones for the ix?
                Can someone provide a link to their preferred vendor who sells Koni SA's?
                  I've bought 2 sets of Konis from these guys (1 I'm just now installing). I get the hardtop fronts as the cabrio spec is not top adjustable and the compression valving is very close (rebound is adjustable so doesnt matter). In the 2-3 years since I put them on my cabrio they still make me smile.
                  PNs 8641-1021SPORT & 80-2522SPORT for $506 and I got $50 back from Koni. Cant beat that. This set going on the coupe w new H&R Sport springs and the other is in the cabrio w H&R cabrio springs
                  importrp.com
                  In WA and good people to deal with. I also just bought rotors and pads for my Touareg from them.
                    Koni puts on a sale every spring. Prices are pretty consistent.
                    Patrick Henry
                      importrp.com
                      Thanks gentlemen for the input. I will be contacting your vendor within the next month to order those goodies! It seems like those prices are the lowest after crunching the numbers. I'll keep y'all up to date.
                      Things I plan on adding to the purchase:
                      Boge strut mounts up front
                      Turner Motorspots rear shock mounts (is this even needed?)
                      Reason for doing my research is this. Happened after 400+ miles of driving straight.
                      IMG_3664 by lorenze torres, on Flickr
                        I've never seen a strut mount tear out that way. If I had to guess I'd say someone used an impact wrench to install that strut and did terminal damage to the threads. Stock strut mounts should be fine and an HD rear is not a bad idea. You really want to get some rear reinforcement plates too. They are cheap and take no effort to install and don't forget tomorder some RSM gaskets unless you enjoy making them (easy enough to do)
                        Ps when you are ready to pul the trigger on your major parts still price check and if a vendor is good on some parts and not on others don't hesitate to ask for a price match.
                          Agree across the board here.
                          Patrick Henry
                            Anyone else have trouble with vertical clearance over their M20 engine with a strut tower brace? My old Dinan brace was meant for E30, but was very close to the throttle cable bracket, and eventually broke off one of its tabs. It's off now, and I'm looking for a new one with better clearance.
                              I just repositioned my cable by bending the bracket slightly. Have a sparco
                                I'm looking at the Mason Engineering brace online, it looks good and has the clearance I want. Says "front and rear studs measure 36.20" c-c". Measuring on my car, with no brace and wheels on the ground I'm at 36.41". Will forcing an additional 0.21" spread be a problem? I forgot to measure what the spread was with the Dinan in place.
