The Detailed E30 R-134a Conversion Thread/DIY
    Originally posted by ///M42 sport View Post
    read on this thread to go with seltec or sando but cant find specifics on where or model
    I bought a denso.. no issues here
    Sent from my Pixel XL using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
      http://www.partsgeek.com/catalog/199...ompressor.html
      other than the top plate difference not sure what else is different between the denso models
        You use your old top plate from the old condenser. Comes with gasket and everything else you need
          Anyone else running a seiko compressor? my 92 Mtech came with this and the front flange behind the pulley is leaking so I need to purchase another compressor.
          Is it wise to convert to the denso everyone seems to be running or just buy a reman seiko compressor? There doesn't seem to be much data on this specific model and its merits. From what I understand mounts are no longer being made for after market compressors so I am stuck with OEM options.
          BMW part # : 6452 1386 464
          Seiko Seiki part # : SS-811PB3
            Can't see pics anymore, just when I need to!!
            E30 | E46 | E53 | F31
            Collection of my DIY Guides here
              Yeah. I'll have to see what's going on there
                Well, Photobucket can go fuck themselves.
                Pics are in here:
                http://s687.photobucket.com/user/glu...?sort=3&page=1
                  Pics are in here:
                  Add my middle finger to the Photobucket rant. They are asking more than Hulu, Netflix & Amazon Prime combined...for what...hosting a few 100 pics !!
                  End of rant :-)
                  Deck Lid and soft top Shocks on hand
                  Seat shocks on hand for immediate shipment
                  Alice the Time Capsule
                    Found a leak at one of the A/C drier connections on my Touring. The system is 134a converted.
                    I bought a new high pressure switch and Behr drier from AutohausAZ, and am hoping someone who's been through this can give me some advice before I unintentionally ruin the new drier.
                    Here is a pic of the new high pressure switch.
                    new high pressure switch 7.4.17 by cory58f5, on Flickr
                    Here is a pic of the port on the drier for the high pressure switch.
                    new drier 7.4.17 by cory58f5, on Flickr
                    So, the obvious problem - they both have male fittings. Does anyone know if the schrader valve fitting on the Behr drier is removable? The old drier I took off the car has a female port for the HPS.
                    Thanks, Cory
                    1992 325i 'vert
                    1988 320i Touring
                    1977 530i
                    2015 328i - Euro Delivery/Performance Center Delivery
                    2001 325i - R.I.P.
                    BMWCCA
                    E30CCA
                      I've bought quite a few Behr driers and not one has had a male fitting or a schrader valve. You don't want something to keep thenswitch from bleeding down.
                        Agree 100%. Just wondering if anyone has removed that fitting. It looks like the base is part of the casting, and the Schrader valve part is pressed in, which would mean that drier is not compatible with the HPS.
                        1992 325i 'vert
                        1988 320i Touring
                        1977 530i
                        2001 325i - R.I.P.
                        BMWCCA
                        E30CCA
                          Are you sure it's the right dryer?
                            I don't know why anyone struggles with converting to R134a, just run R12a.
                            Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                            Your resource to tools and tips: www.rtstools.com
                              My thought too
                              You KNOW the answer to that :)
                                Noid and Jeff - I think it's the right part, but have never done this before. I cross-referenced the part number from AutohausAZ and it comes up as the correct E30 part on ECS Tuning and FCP Euro. Here is the page from FCP, showing a picture of the drier I received, with the Schrader valve fitting in question.
                                https://www.fcpeuro.com/products/bmw...hr-64538391025
                                Thanks, Cory
                                1992 325i 'vert
                                1988 320i Touring
                                1977 530i
                                2001 325i - R.I.P.
                                BMWCCA
                                E30CCA
