Shift Lever and Short Shifters
    Originally posted by JoelRKaplan
    It seems that the 1.9 lever(...148 ) is on backorder in most places. Also the 148 lever has been superceded to a 252 or 256....something like that. Has any1 confirmed the new p/n to be the exact same lever? Sometimes parts are modified slightly when they get new numbers........its usually insiginificant but I was just wondering. Does any1 know where a 1.9 lever is in stock and available now?..... I also had heard from a well respected supplier that the M3 e36 lever was equal to a 1.9 throw but a bit taller "in car"......any one?........tia!
    why is that face there.....it shows as an 8 in my post for editing?????
    got it......!
      bulletin board code recognized the 8 and the ) characters together as the cool guy smiley emoticon. Just put a space in there: (..148 )
        1.9 lever
        Does any1 have a 1.9 lever not installed yet? I would like some measurements please......pm me or whatever......or jrk@jrkchiropractic.com thnx!!
          anyone bothered that the shift pattern has shifted?
            It seems that the 1.9 lever( ...148 is on backorder in most places. Also the 148 lever has been superceded to a 252 or 256....something like that. Has any1 confirmed the new p/n to be the exact same lever? Sometimes parts are modified slightly when they get new numbers........its usually insiginificant but I was just wondering. Does any1 know where a 1.9 lever is in stock and available now?..... I also had heard from a well respected supplier that the M3 e36 lever was equal to a 1.9 throw but a bit taller "in car"......any one?........tia!
            I have the "new" 1.9 lever that replaced the ...148 part number. As fas as I can tell it is exactly the same. The measurments match the measurments on a #148 lever that somebody posted online awhile back.
            Aaron
              Okay, theres way too many pages for me to read through, and a shitting session isn't long enough. Would anyone would like to post up a summary of all the Z car shifters, and which does what, and who likes what better? Along with some part numbers?
              My drinking team, has a racing problem.
              Anyone have an aquarium? If you want fish, let me know.
                Check the first page.
                Basically, the longer the bottom, the shorter the throw.
                3.0i is VERY notchy and VERY short - I love it!
                1.9i is not notchy, and still a little short.
                - Sean Hayes
                  I think VERY is a bit of a stretch. I love it to death, and can't picture driving the car with any other lever.
                  MAKE SURE you replace all other bushings related to the shifter and carrier arm - it will make or break the improvement of the new shift lever you choose!
                    Oh, me either.
                    BUt compared to the 1.9, it's a lot shorter. Compared to stock, it's VERY short.
                    Hell, it's shorter than my dads UUC shifter in his M3, by far. I LOVE myt 3.0 shifter! :D
                    - Sean Hayes
                      It's so minute that it's not even an issue. I never even noticed after I installed the lever. The knob will probably move forward and to the right about 0.5".
                        Gotcha. The thing I was refering to was clearance problems. I'm not sure if I get this right, but:
                        Ones with clearance problems can be solved by 1) Taking off the balancer, or 2) Taking a whack to the end of the shifter.
                        That said, I want something stupidly short. 3.0 would work right? What are the part numbers I'm looking for? I need bushing numbers, I plan to do this after this weekend.
                        If I were to head over to a BMW dealer, could I just talk like a stupidguy and just say, "I NEED z4 3.0 SHIFTER w/ BUSHINGS!" and have them understand my language?
                          Goddamn. I could have sworn that first post was shorter than hell. I hadn't realized that you were updating it. I'll just shutup and read first post. DAMN good job on that. Its rare that people update their first post, so sorry!
                            It hasn't been updated in forever. One of these days, I'll go thru all the posts and update it. lol
                            Yea, you cna go to the dealer and say you need the 3.0i shifter, and they should be able to find it. A P/N is always better though. Eliminates any possible human error on their part. ;)
                            As long as you don't have a harmonic balancer, the 3.0i will work fine. While I had my car apart for my rebuild, I bent my selector shaft a bit to work in conjuction with the 3.0i shifter. The problem you can run into is that the selector bar will go into the selector joint (thing on the end of the selector shaft) at an angle, causing quite a bit of resistance when shifting. So I bent mine so that it goes in straight. This relieved quite a bit of the shifting effort I had from before. Combine that with my heavy shift knob - and it actually goes in pretty smoothly!
                            - Sean Hayes
                              hey Aaron,
                              I picked up the new version also...... the vendor said it does NOT use the "washers"....Im thinking its the washers that go on either side where the linkage rod attaches thru the hole at the bottom of shift lever....did you omit those in the install??/////..hope Im clear in my wording...Im too lazy to look at realoem to use the proper terms.... are you happy w/ the lever?..... Im still considering AutoSolutions in addition.........tia!
                                hey Aaron,
                                I picked up the new version also...... the vendor said it does use the "washers"....Im thinking its the washers that go on either side where the linkage rod attaches thru the hole at the bottom of shift lever....did you omit those in the install??/////..hope Im clear in my wording...Im too lazy to look at realoem to use the proper terms.... are you happy w/ the lever?..... Im still considering AutoSolutions in addition.........tia!
                                I haven't installed it yet - it is still sitting on my workbench. When I get to it, i'll post an update.
                                Aaron
