Looking to change my exhaust system up a little bit. I have the Magnaflow 14815 single-in dual-out. I recently fixed most exhaust leaks and now the whole setup is wayy to quiet. I am looking at a Magnaflow High Flow Cat. I ran the system before with no cat and loved the sound. I am looking to use a high flow cat to reduce the smell and some of the rasp, but not the sound. Anyone here using a high flow cat, and can tell me how much the sound changed vs no cat/stock cat?
Stock Catalytic vs Aftermarket
20% Accurate
Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.Tags: None
94008 model if that helps.
I have researched videos and those don't help with the dB difference.20% Accurate
Why is the factory cat so large???20% Accurate
