Well, I Am Going To Add Triple Webers To My 3.0L M20…
  • E30-TourZing
    • Feb 2017
    • 145
    Hello Gang!
    Its been awhile since I posted. I finished my 3.0L M20 a few years back. The motor has been swell, but my standalone experience has been less than appealing. Exactly what I was hoping would not be the case.
    2- year ago I ended up building an entirely new wiring harness from scratch (took roughly 42 hours to complete) and its causing some issues for me now. I recently left my career restoring cars full time and now have a job in a different industry that gives me zero time to spend time working on problem solving my Touring.
    My plan with getting MS2 setup is to run ITB's. Based on my issues with electronics, and the fact I need outside assistance, I am looking to simplify my drivetrain while still having the sweet, sweet power and noise of ITB's. My original concept was to do side draft Webers before I was coached into a standalone, so this is my current direction.
    I have done some research and based on my motor, DCOE 45mm Webers will be the best for the application. There is a mounting plate which is CNC'd and needs to be modified to host 45mm carbs, but the oil tube is clearly different and there isnt much documentation or opinions on this setup.
    Here is the link to the plate - https://www.ebay.ca/itm/361433574358
    I spoke with Webco in UK and Pierce Manifolds directly and neither one of them has any added value on the product. This add on is quite expensive to my motor and I want to be a sure as I can about where I am spending my money.
    Does anyone have experience with this setup on an M20/E30? Because the profile is smaller, does it help clear the booster now? Are their any photos of the oil tube setup?
    Thank you for all the countless times you guys have saved my bacon in the past!
    (Photos are of my current setup)
  • 2mAn
    Señior Mod
    • 20602
    EFI is always going to be better. You're looking at an easy $2k for the manifold and 3 weber 45s and that money can be given to an expert to sort of your issues
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • E30-TourZing
      • Feb 2017
      • 145
      I appreciate your response 2mAn. For sure there is a solution available to keep EFI, but keep in mind this would also want to add ITB's after, so it would likely cost more to go this route. Carbs certainly are not going to be the best case scenario for effectiveness, but it is what I am leaning towards for a few reasons.
      - Mechanically speaking, I built the car myself and I would like to continue that path. With carbs I feel pretty available to working on them once tuned. I spend time around vintage 911's often and it amazes me how little they need once dialed in. Year after year with little use of the car or cleaning, they start up after months sitting and two pumps of the throttle before turning the key. They also perform really well under all load conditions.
      - They look and sound the business. I am into something unique as long as it functions. I really do not drive my touring often, and when I do I am about utilizing all it has to safely offer me on the street. (driven hard-put away clean)
      - I have some carb wizards in my corner who offer great advise and assistance when it comes to these things. Less so with EFI tuning. My good friend who spawned my MS setup no longer lives in the same province and he is a new father which means its difficult to bug him when questions arise.
      My hope is the oil tube from the head can safely lead to the block with this plate and that the booster can still be used (even if its a 944/E21 booster)
      Can anyone chime in on this product and give there two-cents?
      Thank you!
      • digger
        • Nov 2005
        • 6072
        Brake booster clearance is largely determined by the angle of the manifold off the head and the total runner length as well as booster being used and if it has been moved.
        With Webers you want the runner to follow the port centreline and then start to bend over so the actual Weber sit close to horizontal (for functional reasons) and as this would somewhat optimize booster clearance.
        Skifree developed a setup for 2002, not sure how this translate to the e30. The e90 type booster improves things slightly plus its a better setup than the stock e30 booster
        https://www.flickr.com/photos/152898...7688980425565/
        with fuel injection there is much more flexibility in the design
        • McGyver
          • 4589
          What's the cost to ditch MS and go with a professional setup like Haltec? I don't know what it's like for a general consumer, but they seem pretty responsive to Mighty Car Mods. Being a major brand, you're likely to find more support for install and tuning.
          • 82eye
            • Jan 2009
            • 1977
            what would you need a standalone for? on carbs the only thing it could do is time spark, everything else becomes irrelevant. the stock ecu should probably be able to handle spark. if you are running standalone i'd go straight to itbs, once you've tried setting up, tuning, and syncing triple webers you'll be more than ready to embrace itbs and digital tuning instead.
            edit: try a couple e21 forums. that's where m20's and triple webers will be found and probably have more relevant info.
            • TobyB
              • 5240
              No idea on the M20 manifold situation these days- triple Webers are fantastic, but not currently in vogue.
              All I can add is that for a street- driven engine under 3 liters, 40's will probably be easier to tune at low loads.
              You'll have less throttle plate area, and with a relatively small venturi, better idle and transition metering.
              The throttle linkage is important- you can certainly do it yourself, but look up Hal's design on www.2002faq.com
              for ideas on how to do it well.
              DCOEs are their own beast.
              t
              • E30-TourZing
                • Feb 2017
                • 145
                Thank you for all your replies fellas! I am fairly secure on buying the Webco manifold even though there are some unknowns to me about how it is all finalized with the oil pickup and thermostat housing. Regardless it should work. Its also considerably narrower than IE's manifold. I am curious how the performance will differ between the two.
                I have been processing the booster situation, and I am hopeful a e90 booster will be enough. Has anyone moved the booster location more to the drivers side with the E90 booster for even more room? Also looking into a chase bays manual booster, but I don't like the idea of manual brakes on a street car.
                Would running 45's vs 40mm really hurt the torque so much where I might regret it? The 45's will give more jam up high, but I would like it to be fairly progressive in power as its not driven as often in the upper range due to speed limits. Input on this would be great. The Webco manifold is designed for 40mm carbs. So it would be easier on the entire setup if I ran 40mm's. I assume it would need machine work in order to host the 45mm opening. Apparently its 5 axis machine work. Something that might be difficult to sort out locally to me. (forgive my lack of machining knowledge)
                https://www.dbilas.com/en/Intake-tra...le-carburetors - Any input on this setup along with the linkage?
                https://dbilas.com/en/Carburator-sys...03.010.004S-45 - This kit is also quite appealing. I have emailed them to get more information.
                As well, I have looked into ignition options. Technically I could still just use my Megasquirt setup no? This would also allow data logs so I can see mapping of my AFR's. Does the NoDiz setup offer me any advantages? Would I be best off to just run a cap and rotor setup again?
                Thank you all for your input! I cant express how much I appreciate the community!
                - Jan
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3375
                  Cool wagon, aesthetically that's pretty much exactly what I would want...
                  I'd listen to the existing ITB and carb guys when it comes to bore, there are more issues than just lost low end with oversized carbs, they're harder to tune and have worse transient response at low rpm, I've seen this with bikes. You could easily use MS for spark only, and there is probably no benefit to running wasted spark over the stock ignition system on a street NA M20. My opinion is that it would take an insane build to run into issues lighting off the mixture NA, I've run a stock system with MSD coil in good condition with .020" gaps to over 15psi of boost, there are probably more posters in this thread than NA M20s which wouldn't run right with that setup. But keep the wasted spark if you have it already and like it, you can always retain your current standalone setup minus the fuel side.
                  If you do this, steer well clear of their single circuit brake master cylinder, it doesn't belong on any car street or track. To this day they still parrot the line on their website "Most OEM master cylinders are still single feed internally & have the same assumed “risk” to our Master Cylinder." which is just bullshit unless you consider "most OEM setups" stuff like pre-1967 VWs. I'd look into what 24V guys have done as far as moving boosters and undersizing them, clearance is always an issue with M5X swaps.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • E30-TourZing
                    • Feb 2017
                    • 145
                    t
                    Thank you for your input Toby. Dbilas insists I get 45mm Webers for my motor as they feel it will fall pretty flat on the top end. From your experience, would you say this is true? Street drivability is key, but I do love 7,000 RPM. I know you cant get both to perform perfectly, but I am literally getting split opinions on which size to move forward with. Hence my question to people who have real world experience with M20's.
                    • digger
                      • Nov 2005
                      • 6072
                      It is not clear whether you are concerned about making power or justing have it running right.
                      this guy has tested various setups if you look for one below. This is not an m20 but doesnt matter as the power level are same per cyl
                      There are other videos
                      • E30-TourZing
                        • Feb 2017
                        • 145
                        https://www.youtube.com/@PenguinMotors/videos
                        Thank you for this Digger! My intention is to make power as the main objective. My only scare was to loose all low end grunt to accomplish this. After getting sucked into watching videos last night about this, (thanks to digger) I feel more at ease with the 45mm option.
                        Local to me there are some used Spanish Webers available. Outside of the jetting needing to be sorted for my specific motor (which can be expensive) I am weary of buying used to save $1000. If I bought used carbs, my plan would get an ultrasonic cleaner to make things new again. I am not sure if the Spanish Webers are of a higher quality now than before but my hope is they are. Any input on buying used vs new? I can only get one-Italian DCOE Weber from a friend, matched with 2 x Spanish Webers if I go used.
                        I plan to order all my equipment next week. Can anyone lay an option on the Dbilas manifold vs Webco? Dbilas looks pretty simple for the bitch tube, where as the CNC'd plate looks like it will be fairly custom. Outside of that they both seem to be at or near 0-degrees to the head which seems to be the best way.
                        Thank you all for spending the time helping me out!
                        - Jan
                        • E30-TourZing
                          • Feb 2017
                          • 145
                          I am also needing some advice on my ignition setup. I may be eliminating megasquirt as the harness is going to be rebuilt for the carb setup. Although running the TPS on the carbs would be a benifit MS can supply. I run wasted spark, but many have advised me to go back to the stock setup as apparently wasted spark burns out spark plugs. Would a MSD ignition be the best option or should I do a NoDiz, etc? I am open to all suggestions. I just need an easy setup for ignition tuning.
                          • digger
                            • Nov 2005
                            • 6072
                            - Jan
                            The bigger mid range torque loss will come from the excessively short runners, not excess diameter (though neither are ideal). You can choose a suitable choke and increase runner length if space allows to mitigate a bit of excess diameter and similarly if the runners are short you can somewhat kind of make up for it with small diameter runners but this doesn't mitigate as well as the other situation. So you need to look at the big picture how long of a runner can you fit as that may dictate which size is best.
                            the dbilas fits like the stock setup as far as breather tube goes but it may or may not not be the optimum angle off the head for what you are doing, and more than likely you're going to need to have really short runners to clear booster. you can see how it will fit by comparing to their ITB setup and how their airbox runner has a massive bend in it to clear booster.
                            The internal ports on dbilas manifold are not the best if you're trying for a maximum effort kind of thing as they really need the roof to be welded and ported as there is a big bulge in the way (i had this done before the RHD setup existed) but still function fine for most applications out of the box.
                            i would have a chat to Rama at RHD he used to run webers before developing the RHD kit and he will be able to give you some options
                            • E30-TourZing
                              • Feb 2017
                              • 145
                              Thank you for the details Digger. I have reached out to Rama, and they do not have anything to do with carbs any longer. I am about to pull the trigger on some 45's Webers. My options are between a 5 progression hole vs 3. The cost is about $1000 more for the 5-hole. The seller/tuner (based in England) says the 3-hole setup would be fine since I have a SOHC. I can understand how a 5-hole would work more smoothly, but it would require more tuning etc. I dont mind spending more, but only if it makes sense. Any advice between the two?
                              Does anyone know is Andrew (SkiFree) is still around? He seems to have all the answers I may need, but he hasnt been active on any of his accounts in 5-years. I recall him being a regular on this form in the past.
