Hi All,
Just got everything taken apart for the water pump / timing belt / camshaft seal and will start putting it back together tomorrow or Monday.
I've been reading through several threads and DIYs on forums and Pelican, but I have some (probably generic) questions that aren't addressed in a lot of them. I had ordered the Bentley from Amazon but it hasn't arrived yet.
My questions revolve around sealants/anti-seize/thread lockers and where to use them when I put this all back together.
Also, I need to find torque values, and I'm assuming I can hunt them down. But if anyone has a link with some quick values, I would appreciate it! :)
Thanks for the help!
Som
- Anti Seize
- I'd like to put a bit of anti-seize on just about every set of bolts I put back in.
- Are there any threads where anti-seize would specifically be a bad idea?
- Liquid sealants
- Water pump
- It appears there are people that swear on both sides of this -- either "clean everything and the paper gasket works by itself" or "just use a smear of RTV on both sides of the gasket and don't worry about possibly having to take it apart again".
- I'm going with the latter.
- Camshaft seal
- Planning on putting regular motor oil on the O-Ring
- What kind of sealant should go on around the seal itself? I'm assuming I just smear it on the outside of the seal and then press the seal into the little aluminum holder?
- Water pump
- Thread lock
- Not planning on putting thread lock on anything.
- Should I?
Som
