Oil Sandwich Plates
    Oil Sandwich Plates
    Does anyone know what the oil filter thread size is? I am going to put a sandwich plate on to allow for oil pressure and temperature gauge senders and need to know which one to order.
    in for some answers.
      3/4-16 unf
      '84 318i M10B18 | 93whp/90ftlbs | 147- Safari Beige | MS2E w/ LC, 2-Step
        Originally posted by Jaxx_ View Post
        3/4-16 unf
        Somehow I doubt this.
        Edit- Damned Germans putting standard threads on a metric engine. Blasphemy!
        http://www.wixfilters.com/Lookup/Par...px?Part=161527
          Same as ford.
          ADAMS Autosport
            The sandwich plate arrived today along with two adapters, 3/4-16 and a 20-1.5mm. Both adapters have almost the same pitch to the thread, the only difference is the metric one is approx .030 larger in dia. than the "Ford" size. The 20-1.5 does not go into a Bosch or Wix filter and the 3/4-16 fits.
              I had no problem with the adapters that came with this guy:
              https://www.mishimoto.com/oil-plate-...h-adapter.html
                While my sandwich plate was a different make it also came with two center adaptors. At the time I asked the question I had not run across one that had both. Thanks
