Hey R3v,
I've been in and out of this forum for years (mostly lurking) and have been in the E30 game for quite some time.
I picked up a shell that was caged, but bare and swapped over all components from my other wrecked E30 into this car. I mean everything!
I've come to the point in this build where I am ready to attempt starting the car, but unfortunately, it's not ready to start for me. When I say not ready to start I mean, no cranking when turning the key.
I haven't done a whole lot of troubleshooting on the side of wire diagrams and such, but I have gone over the whole harness to make sure that everything I can see is plugged in to where it should and that all grounding wires are seeing a proper ground. Here's what I can tell you
Any help would be greatly appreciated. If I don't hear from anyone, my next plan is to DL a troubleshooting guide and begin tracing CCT's until I find the reason why the starter won't fire.
Thanks,
Ian
- I know there's power to the ignition switch and I know when I turn the key to the on position it lights a large gauge green wire.
- I know the DME is getting power as I can hear the IACV making a noise when I turn the key to the on position
- I know the starter works as I can jump it to make it run
- I've remove the check panel from the car and have left the plug with nothing plugged into it.
- The lights in the dash do not turn on. I mean none of them at all.
Thanks,
Ian
