This has been resolved. Issue was three of the six brand new "flow matched" injectors don`t actually flow. They ended up on the same elctrical harness and they all diagnostically tested like they were operating (internal solenoid would energize/click), but the valve was not actually allowing fuel to flow through. So, even if everything says that the injector is functioning, if you haven`t seen it actually flow fluid, you can`t be certain.
I just swapped in a freshly rebuilt m20b25 and after going through some fun to get it started (had oxidation in the harness preventing one bank of fuel injectors from firing), I have now encountered my next bit of fun....car fires right up, cold or warm, but runs very poorly. The particular symptoms are a fundamental lack of response to throttle input (very slow to rev), no power, and general "rough" running. Idle seems a little rough, but it doesn`t "hunt" or fluctuate. It is tough to actually say that it is rougher than I would expect as the car is a stripped and prepped race car, so everything is a bit loud and rough. Under attempted acceleration, the car does not give any indication of wanting to stall, it just does not deliver power in any appreciable manner. Revs will climb, but are very slow to do so. I did have one instance of what seemed like fuel cut when I got it above ~4500 RPM on an incline.
As part of my prior no start issue, I have already done a fair amount of system checking...
- This is a freshly installed rebuilt M20B25 long block. Prior to removal of the old engine, the supporting accessories supported 8 solid hours of track time without a hitch. Doesn`t mean something hasn`t developed or gone goofy during re-install, just a note that I am not currently suspecting fuel pump or filter at the moment
- I have spark at all 6 plugs. Have not yet pulled them from my drive, have a mix of calls and waiting for the engine to cool completely before I start digging in
- All fuel injectors are firing. They are all fresh rebuilds as well. One bank does make considerable more noise than the other
- Fuel system is correctly hooked up
- Throttle cable is adjusted to spec
- CPS is brand new
I am thinking timing, but before I go through the pain of draining and refilling the cooling system again I was hoping to get some other expert opinions! Maybe a vacuum leak?
- CPS is brand new
