Bmw Oem part avail to mount zf6 speed transmission (2005+) into e30
    Question regarding this item from zionsville.
    Is this for 2008.5+ compatibility with E36 style flywheels, or for all newer ZF6 wanting to run an e36 flywheel?
    There is a local 2007 328i 6 speed for sale, I'm looking to run with my M52B28/aftermarket single mass 240mm flywheel.
    Originally posted by priapism
    Originally posted by shameson
      anyone have a list of ratios for the ZF 6 speed that will fit the m20 in place of the G260?
      im assuming there is more than 1 set of ratios?
        IF you wish to run an aftermarket flywheel; just purchase one for e46 330i zhp or z4 3.0 6mt use. BEST use of time/effort; sell the flywheel not designed for ZF 6 speed.
        I actually have never seen that item; its discontinued and I would likely be scared of it causing vibrations.
        the 2008.5+ ZF 6 speed gearboxes have the pilot bearing INSIDE the input shaft; - ***YES INSIDE***; its pretty insane. no pilot bearing in the engine or flywheel
        you only have 2 options really; to match the angle of the M20 engine you need a DIESEL 6 speed unit
        E46 320D late model 2005/6 gearbox (earlier had 5 speed)
        OR
        e90 320D
        Both will have short 1/2 gears and 3/4/5/5 spaced pretty close for turbo
          Thanks H, I just bought this ZF320 flywheel/clutch setup and new OEM bearings, slave, etc. Too much money to start again right now, maybe in the future.
          I found one mention of that zionsville piece vibrating loose... lots of potential to damage things there.
            Zionsville piece should be ok; I'd use loctite on the screws.
            if it were to fail or vibrate loose it would be UGLY.
            the e90 part seems to fit the e36 auto trans x member pretty well; someone has a good thread on BFC with this (also from the great land of canada)
            If you have a new zf 320 setup you could fit a e36M3 euro 6mt on it and use the garagestatic v8 6mt trans mounting items:
            http://store.garagistic.com/e30-v8-6-speed-bracket?
              The figures in this chart are with a 3.15 diff. It is possible the GS637DZ has different ratios to the GS637BZ. I am finding 1st gear so low on this box I am just using 2nd gear from a dig with the M50B28 turbo vanos motor. I'm running a 3.25 LSD diff at the moment.
              89 M50B28 turbo
              LINKY
                I have the zf gs6-37 transmission from an E46 330ci I believe. installing it into my E30 that has S52 w/ g260
                Just ordered my 22 spline clutch disc w/ e36 m3 pressure plate from UUC,
                I got the pilot bearing adapter from TC Kline (i think. zionsville has no interest in selling it anymore individually)
                Ordered the double sheer shifter carrier, and factory selector rod.
                now im going to order the part mentioned in the OP, looks great thanks for sharing! too bad its not $20 anymore haha.
                Now I'm wondering, should I just fabricate something together for the bottom piece / cross member or is there an OEM piece I can buy that gets pretty close?
                Do i use the E90 automatic one or the E46 6 speed one.
                I currently have a white325is brace.
                  I can't find that adaptor on the tc Kline website. Do you have a part number?
                  S52-Powered 1987
                    Use a 330i FW. What FW do you have (if any) right now?
                    89 M50B28 turbo
                    LINKY
                      Just bought a used g260 and sold my 3.25 lsd. Fail x2. Great info though. Thanks!
                        I have the e36 M3 one that matches my e36 M3 trans. I have an e46 M3 6-speed that I'm going to install this fall and I just want to get the pieces together. Trying to figure out if I need a new flywheel and that adaptor or just a new disk.
                        S52-Powered 1987
                          Bump for any more new info out there
                            1. s52 flywheel bolts happily to S54 (and obviously s52) and works with 5 or 6 speed.
                            2. pressure plate must match flywheel.
                            3. friction disc must match transmission;
                            1/2/3 must also be compatible physically.
                            A. S52 engine S52 flywheel+ 6mt Getrag 420 friction disc + s52 pressure plate + 6mt g420 getrag transmission is proven compatible.
                            B. S54 engine + s52 flywheel+ 5mt ZF320 with s52 friction disc+s52 pressure plate was my own choice.
                              Originally posted by Wanganstyle View Post
                              A. S52 engine S52 flywheel+ 6mt Getrag 420 friction disc + s54 pressure plate + 6mt g420 getrag transmission is proven compatible.
                              Did you mean S52 or S54 pressure plate?
                              I'd heard that the G420 has a short input shaft and the pilot bearing is in the flywheel? That's why I'm asking. Just trying to plan ahead so I'm not air-freighting heavy parts around trying to get my car back on the road in minimum time.
                              S52-Powered 1987
                                Look at photos on the interwebs.
                                Dont ask for spoons to feed on
