Clutch pedal woes
    Clutch pedal woes
    Hi I just hopped in my ‘87 convertible only to find when I pushed the clutch in, it went right to the floor. I’m sure it’s happened to many many people but never me. Is this a clutch slave cylinder issue, pedal itself somehow breaking? What should I look for? Any troubleshooting agenda?
    Thanks.
    NealF
    Thanks.
    NealF
    A wet carpet would indicate your input cylinder that is attached to the clutch pedal is leaking.
    Do you have brake fluid in the reservoir?
    Slave cylinder internal seals might be shot
    “There is nothing government can give you that it hasn’t taken from you in the first place”
    Sir Winston Churchill
      Re
      Carpet is not wet. No fluid on ground either. Is the clutch Slave/clutch master a job for a DIY’er?
        Re:
        So I realized My fluid level in the reservoir needed to be topped off it wasn’t reaching the fabric line to the clutch stuff I filled up the reservoir and got a little bit of pressure in the clutch pedal close to the floor. Will it build up any more than that or is it something else?
          If you are missing fluid, that means there is a leak. I.E. - The master or slave has failed.
          Look under the car and find the slave on the side of the transmission. Pull it out and take the boot off and look for fluid. If it looks dry, it is likely not the issue, meaning the master is bad. Often times it will be leaking, but the boot hold the fluid so you might not see a leak underneath the car.
            Update
            Once I added fluid the pedal came back to normal and I took the car out. Upon return I saw fluid on the ground. Now I will start to figure out where the leak is occurring from.
            Thanks
              Once you identify the leak, If i were you i would change the master, slave, the fabric pipe and the clutch reservoir all at the same time. The master and slave can be a few dollars but the pipe and the reservoir are cheap as ($20 AUD for the reservoir from genuine bmw). If the master is buggered, the slave won't be far behind.
              On the master make sure you buy the little plastic nipple that goes between the master and the rubber pipe. In my experience these cannot be re-used.
              Everything will be new, you will only have to bleed the system once, and you wont have to touch it again for another 20yrs.
                General Discussion is not a catch-all; please do not ask technical questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
                Originally posted by kronus
