Is this an LSD?
    Is this an LSD?
    Can anyone tell from this photo if my diff is LSD or not? I'm thinking it's not, but need to know what kind of fluid to fill it with. Thanks.
    Sent from my SM-G960U using Tapatalk
    1988 Alpinweiss 325i Convertible
    yes, lsd
    Lorin
    The M30 is God's engine.
      Thanks. I couldn't tell because the tag was too rusted.
        Google it. Seriously.
        If both output shafts spin together it's an LSD.
        "Tires are our fuse" -Matt Juengel
        1986 325e Sedan | M20B27 parts available for sale |
          Thank you.
            Unless it's a mechanical locker like a torsen.
              General Discussion is not a catch-all; please do not ask technical questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
              Originally posted by kronus
                I prefer Redline 75w90 or comparable GL-5 fluid in clutch typs LSD's (such as a stock e30 would have).
                ...or helical, but highly unlikely in an e30 diff....Torsen came in some z3 diffs, though.
                john@m20guru.com
                Links:
                  You can sometimes provide enough load on one output flange to cause a torsen to show function, haven't had a chance to try a helical setup the same way.
                  As an aside, torsens aren't bad in the snow and icy stuff the way I thought they might be, as long as you have even a little grip somewhere you'll go, and when you don't you can brake torque it.
                    Both Torsen and helical will act like an open when one wheel is completely unloaded. This is why they both rotate the opposing wheel opposite when sitting on a bench.
                    Quaife is a 100% helical (I used one in the ls1 swapped Mercedes), but they both actually act similar when a wheel if lifted, but deceleration is argumental.
                    Torsen:
                    https://www.youtube.com/watch?v=JEiSTzK-A2A
                    Helical:
                    https://www.youtube.com/watch?v=W96fOdMZnXE
                    EDIT: Now a viscous acts in a very different way - kinda like a torque converter does in a slushbox transmissions:
                    https://www.youtube.com/watch?v=GDlTOPr_Acs
                    john@m20guru.com
                    Links:
                      A clutch pack (Salisbury), Torsen or Quaife can all load up and prevent wheelspin, up to the limit of their capability.
                      A viscous unit can only react to wheel spin.
                      I thought Quaifes had a small clutch pack or preload spring in the center that gave them something to push against so they can move the car even with one wheel off the ground.
                        I thought Quaife was another name for Torsen
                        Deck Lid and soft top Shocks on hand
                        Seat shocks on hand for immediate shipment
                        Alice the Time Capsule
                          Torsen type 2 units have a couple clutch packs so you can move the car in san Francisco parking situations (one wheel airborne). Does nothing when on the track flat out with one wheel airborne
                          https://www.s2ki.com/forums/s2000-un...embly-1161293/
