Corvette C4 IRS Conversion
    Ok so some may be familiar with my conversion at this point - but i've had a few requests to bring it over to this board, so here it goes.
    The suspension is about 95% done, so this post will be somewhat retrospective.
    It may take me a little bit to get all the info posted - as its turned into 30+ pages of posts on other boards. This will be the abridged version
    Quick recap:
    built the car, and ended up with way too much power for what the stock rear could handle. traction was a huge issue, and i was hesitant to stick we all BMW parts due to the cost (driveshaft shop axles, etc) The car is alot of fun as of now - but not getting traction till 3rd or 4th was wearing thin. Racelogic's traction control only went so far.
    couple goals i had in mind:
    - fully adjustable (camber, toe, instant center)
    - unbreakable
    - affordable parts
    - good balance of street / strip
    - and partially just a project to do
    had some good suggestions, but decided to move forward with a C4 (84-96) Vette IRS swap.
    main benifits:
    - 3.5" axles!
    - aluminum , light weight
    - Dana 44 diff (unbreakable)
    - domestic parts are cheap!
    - 4 link
    - still an IRS.
    Here is what a C4 vette IRS looks like
    Half Shafts
    Tire size evolution
    205 - 245 - 315
    trying them on for size - Hoosier Drag Radial (315/35/17)
    making clearance
    So how is all this going to work?
    Subframe will be constructed from 2"x2" .083 mild steel tubing.
    Just ordered a set of CCW Classics. 7.5" up front, and 11" in the rear.
    Once all is said and done, i'll drop the car off at a local chassis shop for a chromoly cage to tie it all together
    As off last night, i'm working on a jig to position the rear at the exact locations to build the subframe around.
    Subframe will be welded off the car, and then tied into the chassis as one unit.
    a long way from home
    made some more progress.
    CCWs show up friday! hope i can get them mounted too, well at least the rears
    here's what the subframe will look like
    got some more parts in today
    stopped by S&W race cars, where i had some of the custom brackets waterjet cut
    test fit
    also picked up some 2 x 3 tubing, and this drop down cross member. There should be enough room for the driveshaft to some through, and the exhaust to fit on the lower left corner. This is just in place for mock up, there will be 1/8" steel plates welded to the rocker panel first
    tomorrow the wheels show up! can't wait.
    wheels showed up - getting tires mounted now
    600hp beast
    back from a long day at the shop. Had my buddy jon up, and we were able to bang out some ish
    jon brought up his wheels for me to check out and, and we tried his 15" welds on my hubs - they fit! which is awesome, because now i will be able to run a more conventional drag tire if needed
    so first thing first, i cleaned up the rocker panels so we could get some 1/8" plate welded to them for the subframe to tie into
    we then got the front half of the subframe cut out and tacked together.
    with everything positioned, we marked where the four link bars intersect
    took it back over the welder, and tacked it all in place.
    we have some scrap welded to the 1/8" side plates so that we can set the subframe in without too much struggle. end of this tube will be boxed in
    theres still some debate on track width. Jon thinks i need to move the wheels in more, and he is probably right. I need to get the 4 link bars for the passenger side, and get both wheels in there before i make that decision.
    we ran out of steam before we could get the other bars cut to length that run front to back - but theres always tomorrow
    so i was able to crank out some work the past two days
    have the front half of the subframe all welded up
    tonight i finished up some work on the back part of the subframe with the diff mount, etc. we were able to position the diff in the car for the first time and get a glance at how the axles will in up
    we sectioned out a good bit of the stock axle..
    back view
    bottom view
    front view
    got some parts back from s&w that i had waterjet cut..
    - new rear diff mounts, with two mounting holes so i can 'raise the body' without effecting suspension geometry
    - upper shock mount tabs
    - diff bracket for camber adjustment rods
    I also picked up some 3 piece rod ends and chromoly tubing to make the camber adjustment rods.. damn that shit is way too expensive, but they only had the 3 piece stuff in stock in both right hand and left
    This week i also machined up some lower shock mounts, which will bolt to the wheel spindle housing... the stock corvette actually had a monoleaf spring so there was no provision for coilovers. My mount bolts into where the shock would bolt to
    (note, the mount is not tightened to the housing in this picture)
    i'm hoping tomorrow i get to crank out some work on the car. I want to be able to get my axles on order and figure out the driveshaft.. then its on to doing sheetmetal work
    welded up the back part of the subframe. Adding the upper shock mounts, the new diff mounts and fabb'd up the front diff mount
    got everything back into the car - and used a plumb bob to drop points onto a piece of plywood to check alignment of everything, and then tacked it all to the car
    then i reassembled everything to double check fitment, and it all seems right on
    messed around a little bit with the rod ends for the camber adjustment bar.
    next will be axles and driveshaft and finish welding of the frame. I'm trying to decide mig or tig. I have the mig in the garage, but would have to tow the car down the street to the tig
    also, gonna order up some springs and my fuel cell tomorrow
    scary to see how much was taken out of the axles (for mock up only)
    got my 15gallon fuel cell in today, and finished up the camber rods - complete with all the spacers and whatnot
    test fit (like if it was made for the car)
    shot of the back with 90% of the junk bolted up. Just need the real axles and to make the toe adjustment rods..
    oh and some sort of sway bar
    also picked up this beast to help with some of the sheet metal work
    got a second to mess around tonight. Tried my hand at my first panel. Turned out ok, but the bead roller is hard to get the hang off - it wants to go all over the place
    spend alot of time this weekend drilling spot welds and removing the existing trunk floor. here is what was left
    and now my new panel
    also mocked up my toe adjusters. need to weld something to the diff cover for these to attached to
    sway bar tube mounted.. (pardon my semi crappy mig weld on that one side)
    and now for the good stuff - new axles!
    bummed out that my drive shaft isn't here yet.. DSS is taking a good bit of time. Called frank today and he said "well i'm not sure why its not done, i guess thats why you are calling huh?"
    thats all for now....
    600hp beast
      i'm so f****en shocked.
      that's sooo awesome.you must be tired.
        Nice work! Looks like a fun project... now I have to ask, what is powering your beast that you are getting 3rd AND 4th gear wheelspin??!
        Mike
        82 Alfa Spider (For Sale)
        86 944 Turbo
        87 CX25 TRD Turbo2
        89 405 Mi16
        89 Milano Verde
        89 Mondial t Coupe
        92 300D
          very cool.
          what motor is in this thing? Are you only going to use it for the drag strip, and what front suspension are you running?
          Originally posted by vlad
            Wow impressive. I think last I saw your other thread was on BF.c
            So whats under the hood?
            92 Granite Silver Vert
            M60B40 5spd
              hey guys thanks
              under the hood is a built s52 - low compress motor, running 22psi on a GT35r.
              I made 562whp and 580 tq back in april and that is kinda what lead to this project - i was sick of spinning tires all the time
              i'll post some more of the suspension build in a few
              600hp beast
                ok so on to cage fab.. I decided to do this in house after getting some quotes and long lead times
                here is some pics of the mock-up.
                need to weld in my 6x6 plates here
                nice match of the body
                anchor points for rear of cage
                lots more to fit and adjust. door bars, i'm still trying to decide if i want to do swing out. and there are two more diagonal bars that go in the hoop / cross bar to the rear subframe cross member
                oh man, just got back from a long day at the garage. working on the tin work, and got the floor plates welded in for the main hoop
                the passenger side was a bitch because the stock wheel well is all over the place to account for the fuel tank fill
                pro street anyone?
                then i switched over and formed and welded the floor plates - not an easy job with 1/8" metal
                more worky
                did a little work this weekend - but not as much as i wanted too. It was just too damn hot out in the garage...
                the car is finally sitting under its own weight.. still needs some adjustements for camber / toe ,etc. And the car will be raised up another inch or so. I was happy however that it rolled in and out of the garage smoothly. it all needs to come back apart before its done for painting, etc. but i needed to be able to roll the chassis around to take it down the street to TIG weld the cage.
                i guess i'll update this thread more often since my other one got locked ( on BFC)
                finally got the correct parts in for my drive shaft shop drive shaft.. 3" chromoly
                mounted up nicely, but i needed to clearance the tunnel and temporarily get rid of the ebrake.
                plenty of clearance about the 2x3 cross member which is important because i designed the whole suspension to be able to drop down 1.125" inches to different mounting holes for added wheel clearance but still maintain the correct geometry. Also got my rear drive shaft hoop in
                also worked on getting my subframe bars fitted to tie the subframe 2x3 crossmember to the roll cage.. this was a major pain in the ass. you can see my e-brake filler plate here. i'll probably have to mount something on top of this for e-brake
                hoping to take off work friday and tig the cage..
                then everything needs to come back apart for paint.. fuel, auqamist.. then its pretty much ready for the road
                took the day off work yesterday and got the cage fully tig'd.
                still need to do the door bars though
                600hp beast
                  slowly making progress.. i'm hoping to get the car primered underneath, seem sealed, etc.
                  got the front and sides of the tubs done. really makes it look cool.
                  think there will be enough room?
                  only one more panel to make (what would be the panel behind the back seat). then i just need to finish my welds here and there and start to re-assemble
                  other cool thing is the stock rear door panels still fit! so it will look super stealth with some carpet covering everything in the back. :)
                  little update
                  trying to finish up the door bars before i seriously throw something at the wall.. frustration trying to get everything to fit - and i'm not at all happy with the swing out hinges i bought but i'm trying to make them work.
                  short end of it is - the door bars can't be in place for 'street mode'.. the door panels get in the way - so most likely i'll just run the door bars at the track and pull the door panels off
                  hope the door bars are up high enough - they are supposed to pass through between your shoulder and elbow. But i have a feeling i'll be tearing the door bars out within a year and going to a full 10 point cage so it probably won't matter much
                  and i've finished all of the sheet metal panels
                  if you can't tell - the project is starting to wear a little thin on me :(
                  little update since i'm having a slow day here at work
                  I had to revise my camber rod mounting points on the diff as the pressure bent them outward when i set the car down..
                  so i had another plate waterjet cut that goes behind the rod ends. prevents the bolts from being able to spread out.. I'm most likely going to weld in a plate between the two plates to make a U channel of sorts
                  I also got the diff cover back from having a chunk of aluminum welded on to mount the tow adjustment rods.
                  now i gotta spend some time cleaning it all up and powdercoating it before it goes back in the car
                  killed some braincells tonight, and epoxy primered the underneath.. looks cool now that its all one color.
                  next, to slather on some seam sealer and then undercoat :)
                  finally found my memory card for my camera. then i lost it again, then i found it :) all in the matter of hours. but here are some new pics after the undercoating.
                  some of the pics don't lend themselves to how great it turned out.. i had some friends over last night who were amazed at how much different it looks now over just two weeks ago.
                  and now i'm starting to lay out the fuel components
                  600hp beast
                    Jay post up the vid of it. Your fab skills are killer dude!!!!!!
                    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                    ____________________________
                    E-mail Panayiotisx2@gmail.com
                    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                      thanks again!
                      haha i'll get to the video.. gotta keep them in suspense :)
                      600hp beast
                        did a little bit of work over the weekend. started in on the braided lines for the fuel.
                        I also finished up my camber bracket and did some powder coating.. Accidentally used the wrong red on the calipers, but i kidna like it
                        here is how the camber bracket came out, with the extra back piece and boxing it
                        and started bolting up some of the components.. tomorrow i'm going to throw in the diff, axles and driveshaft
                        made my -10 fuel rail, its huge!
                        old verses new
                        got all my lines made, and new regulator and filters installed
                        primered and undercoated the truck
                        tonight i should be able to finish getting the tank installed and hopefully fire it up..
                        although i don't have brakes yet, so i can't drive it around for a few more days :)
                        key was turned! all went well. i'm uploaded a video to youtube here.. just shows the suspension and a loop around the parking lot at low speed
                        i'm super happy with how the first test run went.. really no problems at all.
                        the car sat lower than i wanted when i first pulled it out, as it settled more than i expected. I cranked up the coils about 3/4" and might do another 1/4 to 1/2 before i leave them
                        ok here it is
                        http://www.youtube.com/watch?v=cfXoLklBpDo
                        crazier videos to come ones i finish up a few small details. like bolting the seats in
                        600hp beast
                          Jay, you are crazy, in a good way ! LOL.
                          P.S. How much hp in your green e34 ?
                            thanks man - yes i am certifiably crazy at this point. haha
                            the e34 is Jon '5mall5nail5' on bimmerforums. his build isn't finished yet, but he is shooting for between 800 to 1000whp i would say
                            600hp beast
                              Damn, what a beast.
                              Do you plan on having such things as license plates on this thing?
                              Just incredible, you shame us all.
                              Luke
                              Closing SOON!
                              Thanks for 10 years of fun!
