Turbo m62 e30
    Turbo m62 e30
    I thought an N/A m60 was a tight fit in an e30... this guy found room for a well designed turbo system. The header primaries are even equal length. Impressive work! Looks like the engine bay remained un-butchered as well.
    From what I gathered in a quick read-through of the thread, he just got it up and running, on 4.5psi. He plans to tear the engine down and build it for 15-18psi once the bugs are worked out. Should be insanely powerful, probably 800+hp. I've seen an 11psi m60 do 640whp in a Volvo 240.
    http://www.bimmerboost.com/showthrea...2-Turbo-in-E30
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    damn
      Hmmh, as long as you can push the engine far enough there indeed can be space for "everything". :)
      With regards to the actual build, based on this picture I'd highly doubt it will hold together for long ...
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
        crazy
        [B]ORDER PARTS-
        kamotorsperformance.com
          Pretty cool!
          I would hate to have to work on that!
            I would love to test drive that thing
              Did he use fence pipe for those manifolds?
              1991 318i SOLD
              2003 325i SOLD
              Racecars and stuff.
                I hope he finds a way to shield those fuel lines.....
                ___________________
                Mark
