91 318is/ LS Swap
    wow amzing
      The dash looks really good. Nice job!
      1988 Super E - RIP
      2019 Ford Escape - DD ;D
      2006 Chevy 2500 Duramax - Race car hauler
      1990 Corvette - Weekend toy
      1986 353 - Snow White, One Crazy Girl - SOLD :(
      1986 VW Jetta (vr6) - Racecar SOLD
      IG: RDE_Fabrications
      Check us out
      Or YouTube --> HERE
        which grit of sand paper did you use and was that just regular body filler?
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
          I used 80 grit the whole time. I’ve read about people going from 80 all the way to 220 but I knew I was putting texture coating on it that would bond just fine. I used regular ole Bondo body filler because from everything that I’ve seen and read the padded dash filler is not worth it.
            Thank you! I've been looking into a way to do this with mine.
            1990 325is
            m52b28
            3.73lsd
              Anybody have experience with cam swapping an L33? I’m debating between a stock LS3 cam and a sloppy stage 2 cam.
                That is a very large cam difference lol
                1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                  Whats the plan? turbo? NA?
                  https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                    N/A
                      N/A
                      HP goal? Max RPM? Are you going to upgrade the valve train? Because the stock springs will limit you.
                        400 wheel, 6500 RPM and I’m upgrading to PAC 1218s regardless which can I go with.
                          Stage 2 Sloppy
                            The rotating assembly will go to 7000 with ARP rod bolts.
                              Sloppy Stage 2 for sure. That is what I will be running in my 6.0
                                Behold the 5.3 L33 out of an 06 Silverado 1500. Aluminium block to keep the weight down, 799 heads for good air flow, and a sloppy stage 2 cam enroute.
