91 318is/ LS Swap
    Originally posted by iansane View Post
    I've seen this suggestion before but if an LS to cd009 adapter is an extra 5-800 depending on who you go through I don't know that it's that much better of an option?
    Taylor Ray on youtube went over this idea as well. He said that initially yes, it may be more but if you were to need to replace the tranny it would then be much cheaper
    1990 325is
    m52b28
    3.73lsd
    g260 (1987 325is 5spd tranny)
      Yeah, and he recently replaced his too, was cheap.
        He replaced his motor, didn't think he replaced the tranny as well.
        1990 325is
        m52b28
        3.73lsd
          yeah it was briefly skimmed over. I think he lost 5th on the first trans?
          1984 Delphin 318i 2 door
            Replace the trans? Unless you grenade the case or something I can't see the need to replace instead of just rebuild/fix what broke. But, everyone has their preferences.
            Originally posted by Tubesock View Post
            There’s actually one near me that’s already modified to fit an LS for $2000. Haven’t found any measurements of it with the Collins kit. I was to make sure it fits the stock hole for the shifter.
            I've bought a couple used t56s off ls1tech for about that. They usually come with clutch/shifter and a bunch of other parts for swaps that I don't need. But shipping ends up being between 150-250 on top depending on who they use. But hell, if that cd009 is close and it's what you want low ball the guy and go get it!
            1984 325e m50nv/G260
            1991 325i Mortdecai the pickup project
            1991 Trans Am turboLSx/t56
            1984 Husqvarna Abomination
              Also heard the gear ratios are better in the cd009 vs the t56. But no real hand experience.
              Anybody know about this claim?
              1990 325is
              m52b28
              3.73lsd
                Measurement CD009
                Total length 40
                Face to output 29
                Face to trans mount center 27
                Rear box dimension 10w X 12h
                http://www.datsuns.com/Tech/transmis...eed_length.jpg
                https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                  CD009 is geared more like a BMW transmission, with a 3.7 first gear, a big RPM drop into 2nd gear, 5th gear direct and a ~0.8 top gear. That's not well suited for a large displacement engine that makes a ton of torque. The overall ratios can be helped with a tall rear end, but it'll always have the big RPM drop going into 2nd.
                  T56 ratios are what they are because that's what works well with big engines that make many torques, especially in light cars.
                    91 318is/ LS Swap
                    Just a thought, and to question your thought process. Have you thought about where your intake is going to be? Depending on how you do this, the radiator hose will be on one side and the alternator looks like it will block the other side now. Edit* hell I don’t know if your hood will clear that alternator...
                    For example...on my car the intake clears the PS pump pulley by maybe 3/4”. There is no way to go the other way due to the rad inlet. Your radiator choice may be key if you stick with that. Curious to see what you do.
                    -Nick
                      Nick, thanks for the pictures, those are extremely helpful! As far as clearance in concerned, I “think” the intake will clear the reservoir and alternator.
                      Looking at the alternator clearing the hood, it sits just a bit lower than the intake manifold so again I “think” it’ll be good. We’ll see when I go to put the engine in the vehicle whether or not I made a bad call going with the Corvette high mount.
                      I got impatient looking for a trans so I bought brake parts and will be doing those this weekend. I’ll finally have some E30 picture for this thread and not just an engine on a stand.
                        Hey man your welcome. I see now the picture you posted was at a weird angle and it looked a lot different than what you just showed. Looks like you will be real close but should be alright. I’ve got all LS1 accessories and it appears you have LS2 or something the pulleys sit closer to the engine. Which is nice.
                        What did you decide for brakes? If you wanna save $$ and if I could start over, I would go with massive’s master relocation which places it up and out. Keep your stock dual pot master and change the linkage ratio. Or did you buy the pedal kit? I don’t remember. Those are the best options aside from a ridiculous linkage booster relocation or hydro boost. Keep us posted.
                        -Nick
                          I’m trying the Chase Bays brake set up.
                            That’s what Im using...it’s definitely a nice setup. I am afraid if the single pot fails I’m effed. Well see...
                            -Nick
                              You like it so far? I was attracted to it because it’s a clean start and simple.
                                Yeah I have had no problems with it. I just installed a wilwood 7/8” master for the clutch hydraulics and while I had the pedal assembly out, I drilled a new hole in the brake pedal. The hole is about 1/2-3/4” higher than the stock location. Hoping this will make the brakes a little bit lighter.
                                They were fine before though, takes a bit of force on the pedal but I could stop in a hurry. FYI I did install hawk hps pads on all corners. Stock calipers....
                                -Nick
