91 318is/ LS Swap
    Yeah looks like you’re battling a little rust under there, I’m glad I didn’t have to fuss with replacing the hard-lines. What are you using for fuel line?
    I’m running stock axles and have yet to break one. Probably because the tires don’t have enough grip but sorry no recommendations on upgrades there.
    You should look into getting wheel studs...and always torque the lug bolts/nuts to spec. We’re all guilty of running em in tight with the impact.
    You also should upgrade the bushings in the rear subframe/trailing arms since you have everything out of there.
    Keep us posted. -Nick
    -Nick
      Originally posted by Tubesock View Post
      While I was working on the rear, found both axle shafts are toast. I am not going to put them back in especially with the extra power coming. Any suggestions on axle shafts?
      Pricey but comes with peace of mind.
      https://www.driveshaftshop.com/impor...-bolt-in-axles
