this thread was originally diagnosing the star issue from when I changed the wiring harness cover 2E 30 and three wiring harness cover I ended up accidentally sniffing a wire that went to pin number seven or I’m not exactly sure which pin but it was it to the ignition switch so we figure that all out but I now have a new issue code 1264 ego heater circuit
not sure if I have to trace wires back in case I accidentally cut something not sure if it’s because I switched DM‘s because I had three different DME‘s that I was using to diagnose the original problem I went ahead and bought a cheap O2 sensor and replaced it but still no change. No idea where to start if anybody has any advice or has ran into this code before what helped you please help me
Need some help can’t remember everything I did
I noticed some wires got pulled out I think for the c101
And I’m not sure where these grounds go, or if they’re power wires
Please assist need help
No fuel or spark
No CEL light
88 chassis
95 e34 harness
No fuel or spark
No CEL light
88 chassis
95 e34 harness
