Cranking, running real rough and cant start
    So I've had a few issues getting my car running after chaning the timing belt. First my battery was dying so my car wouldnt turn over, got that fixed and now its cranking, trying to start and running real rough and after about 5 seconds itll die. I followed the tech no start guide on the wiki, Ignition coil works, ICV buzz's, but I'm not getting spark at the plugs. I changed the spark plugs, plug wire, distributor cap an rotor while doing the timing belt. I went back into the rotor this morning before work and it seems 2/3 of the screws were loose. Would this cause a rough start? Everything is new so it's hard to point and say thats the issue. I bought a new CPS, and relays just incase as i didnt have any spares. Tonight im going to try and redo everything and start it again. Any advice? I thought i read the CPS can cause issues like this.
    85% of the time i have no idea what I'm doing
    I would double check all the timing marks and make sure you don't have the timing belt off 1 tooth. Otherwise, everything else you are checking is good too.
      [QUOTE=AndrewBird;4990984]I would double check all the timing marks and make sure you don't have the timing belt off 1 tooth. Otherwise, everything else you are checking is good
      Will check ty!
        I just replaced the CPS and it’s had almost no effect. Timing is dead on.
          The no start guide is a good resource. If you've already done the CPS and have confirmed good timing, I'd check for bad grounds in the engine bay. Have you taken a plug out and cranked it to see how the spark looks?
          It could also be fuel related. My car would start and die after a few seconds with a bad fuel pump that was barely getting anything through the system. How long do you have to crank before it starts?
            A loose rotor can absolutely impact running and can also damage itself and the cap to the point of requiring replacement.
            Deck Lid and soft top Shocks on hand
            Seat shocks on hand for immediate shipment
            Alice the Time Capsule
              Replaced the coil, fuel injectors, took the rotor out and replaced a stripped bolt, cleaned out the ICV and the car now starts and runs "fairly" smooth. Thanks for all the help!
