M3 head retorque spec ?
    Iím ready to install my cyl head this weekend, 88í M3 ,stock 2.3 . I had a pie shaped burn on(1) #1 cyl ,that I replaced . Iíve got the torque angle tool & have done this awhile back on another product. Canít find torques or how to on utube, any go to sites or info on this install ? Thanks
    [ATTACH]117657[/ATTACH]
    john@m20guru.com
    Links:
      M3 torque spects
      Thank you for that I that info. What is torque ## for those Allen cam tower bolts , angle torque as well ? Where Is all this info w/pics on M3 at ? Thanks ,Joe
        M3 head torque spects
        That pic of the head & torque , was it in the factory shop Manual ? I had that ringed book about 10 years ago ! What was I thinking to have sold it
          I have complied tons of data on them over the last decade or so. I have a small independent shop that ~90% of the clientele is e30.
          Didn't find anything specific on the cam bolts, it just references the generic BMW TQ values based on thread diameter and length.
          john@m20guru.com
          Links:
            Cam tower Allen bolts
            No numbers from them ? Breaking it down it felt like 30-35lbs . Are these angle torqued too , does not seem high enough What ## do you use on an assembled motor . Still donít know why I sold my shop manual ? Thanks again for you help
              For bolting the cam tray to the head
              7mm bolts, 15 Nm (11 ft lbs.)
              8mm nuts, 21 Nm (15 ft lbs.)
                Hi
                50nm,80nm and then wait for 15 minutes and final torque to 100nm, does not require retorting after engine run.
                Kindly supplied buy top guy Pierre.
                http://m3guru.bmwe30m3.net/wp-conten...ine_img_52.jpg
                  S14 head toques
                  Thanks guys for the info !
                    I always double check head bolts that are not TTY after a few heat cycles. TTY bolts that stretch keep the head pulled in as the gasket compresses. A bolt that goes to a TQ value only will lose clamping force as the gasket compresses.
                    john@m20guru.com
                    Links:
                      thanks guy for great infomation
                        Yes I am due to do that on my S14. But not like most engines incl the M20, to retorque the head bolts the camtray needs to come off. Not a 5 min job....
                        Im running ARP studs and retorqued mine after waiting overnight, however I woud like to redo them now the engine has run and got hot... almost 1000kms.
                        Pulling my hair out with all these friggin BMW's:
                        2000 M5 Winter beater
                        1984 318i Coupe 2.5 S14 going in the car below.
                        1988 M3 Lachssilber: I'm the second owner, currently recommissioning.
