[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
    Originally posted by E30335i View Post
    Is there a thread dedicated to your 5 lug of people showing off their wheel set ups?
    No thread.. sorry
    But I can ask to my buyers about their setup & pic
    Then post it here
    [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
    Transaction Feedback
      Couple questions as I was going to go z3 hubs in the rear, but now might do this.
      planning to do:
      z4 rear hubs onto 88 e30 trailing arms (75mm bearing)
      325i/328i e46 rear calipers and rotors
      questions:
      1. I want to confirm if I can keep my e30 Ebrake with this rotor (I think I can)?
      2. What about e30 Ebrake on the 330i rotors?
      3. What would be the brake bias with the e36M3 OEM stock calipers in the front?
      4. e30 rear stock offset is 20mm, and z4 is +2.5mm, so that is 22.5mm offset, so what wheel offset spacers do I need? I am planning to run ARC 8 17x8.5 wheels and they come in 20 offset and 40 offset.
      5. Then if I do all this, do I need a rear fender roll?
      If answers are :
      1. Yes
      2. Yes or no
      3. stock or near stock (good for autox/track)
      4. no spacers with Arc 8 17x8.5 offset 20mm ; yes spacers with those wheels in 40 offset
      5. minimal to no fender roll
      I will take a rear set.
        planning to do:
        questions:
        If answers are :
        1. Yes
        2. Yes or no
        All your questions the answers on old thread here
        https://www.r3vlimited.com/board/sho...d.php?t=325258
        1. Yes, it will retain stock e30 parking brake
        2. Yes, it work with put spacer ring to compensate smaller drum/shoe diameter, or modify the shoe like this...
        http://www.argyrides.eu/bmw/mods/330...ear_brakes.htm
        3. if you using e28/e30m3 25.4mm brake MC, brake bias will be 70/30..
        which good for track and street
        and if you keep with stock e30 brake master cyl, brake bias will 58/42
        stock e30 brake bias is 55/45
        5. minimal to no fender roll, but need to flatten the bulge inside inner fender
        I have stock ready to ship,
        and the price is 135.00 + shipping
          Bump...
            Any way to make an adapter for regular e36 brakes to fit a 15 in wheel in front?
            1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
            Originally posted by nando
            I don't think there's really strong evidence that ZDDP harms cats.
              I can do with e46 325i 300x22mm brake setup...
              and need light shave on caliper carrier to fit 15s wheel...
                I have the e46m3 setup on it now, just not able to find appropriate winter tires that fit. I was considering looking for a different adapter to fit smaller wheels.
                  is that e46m3 with knuckle & suspension or used adapters on e30 knuckle ?
                    Adapters on e30 knuckle.
                      I need your help to measure a dimension, in order to make sure my 5 lug sleeve offset from the caliper mounting to hub is same..
                        Has anyone run an e9X master/booster with this setup?
                        M50 swap that will blow your mind.
                        https://r.tapatalk.com/shareLink?sha...4&share_type=t
                          How much for the front adapters only?
                            Sorry, sold out... even if I have stock, I wont sell front only
                              Oh ok,
                              Maybe you can send me the dimensions of the adapter so I can make one?
                                When will you have stock available and do you ship to New Zealand? If so, how much? Looks like a great kit!
